  3. Issue with Lengthy and Failing Updates
backupsidrivee2
27 Posts 6 Posters 5.8k Views 6 Watching
  • archosA
    archosA
    archos
    Unfortunately, the backups fail to complete again. I have tried to manually initiate the backup process twice, but each time the backup fails with an error, specifically with the Matrix application. I have no idea what to do. I also tried using a Hetzner box, but the backups take even longer there.
    • archosA
      archosA
      archos
      The issue with the backup was likely caused by the Matrix app. I turned off the backup in Matrix and initiated a new backup. Within two hours, the backup was successfully completed. I'll see how the backup turns out tonight.
      Something is wrong with the Matrix Synapse.
      • archosA
        archosA
        archos
        Hello everyone, it's been quiet for a few days since I turned off the automatic backups at Matrix, but today the backup failed again. It's frustrating, and from what I see on the forum, I'm not the only one having issues with backups.
        Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)
        May 25 01:00:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Copying files from 0-3"}
        May 25 01:00:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Copying config.json"}
        May 25 01:00:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Copying data/coolwsd.xml"}
        May 25 01:00:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Copying fsmetadata.json"}
        May 25 01:00:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (1) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:00:26 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (2) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:00:46 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (3) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:01:06 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (4) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:01:26 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (5) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:01:46 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (6) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:02:07 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (7) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:02:27 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (8) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:02:47 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (9) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:03:07 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (10) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:03:27 box:storage/s3 copy: s3 copy error when copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json: InternalError: We encountered an internal error, please try again.: cause(EOF)
        May 25 01:03:27 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Retrying (11) copy of fsmetadata.json. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
        May 25 01:03:27 box:tasks update 10016: {"percent":3.7777777777777777,"message":"Copied 3 files with error: BoxError: Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)"}
        May 25 01:03:27 box:backuptask copy: copied to 2024-05-24-230002-287/app_collabora.arch-linux.cz_v1.17.3 errored. error: Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)
        May 25 01:03:27 box:taskworker Task took 205.487 seconds
        May 25 01:03:27 box:tasks setCompleted - 10016: {"result":null,"error":{"stack":"BoxError: Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)\n at Response.done (/home/yellowtent/box/src/storage/s3.js:338:48)\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:367:18)\n at Request.callListeners (/home/yellowtent/box/node_modules/aws-sdk/lib/sequential_executor.js:106:20)\n at Request.emit (/home/yellowtent/box/node_modules/aws-sdk/lib/sequential_executor.js:78:10)\n at Request.emit (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:686:14)\n at Request.transition (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:22:10)\n at AcceptorStateMachine.runTo (/home/yellowtent/box/node_modules/aws-sdk/lib/state_machine.js:14:12)\n at /home/yellowtent/box/node_modules/aws-sdk/lib/state_machine.js:26:10\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:38:9)\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:688:12)","name":"BoxError","reason":"External Error","details":{},"message":"Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)"}}
        May 25 01:03:27 box:tasks update 10016: {"percent":100,"result":null,"error":{"stack":"BoxError: Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)\n at Response.done (/home/yellowtent/box/src/storage/s3.js:338:48)\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:367:18)\n at Request.callListeners (/home/yellowtent/box/node_modules/aws-sdk/lib/sequential_executor.js:106:20)\n at Request.emit (/home/yellowtent/box/node_modules/aws-sdk/lib/sequential_executor.js:78:10)\n at Request.emit (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:686:14)\n at Request.transition (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:22:10)\n at AcceptorStateMachine.runTo (/home/yellowtent/box/node_modules/aws-sdk/lib/state_machine.js:14:12)\n at /home/yellowtent/box/node_modules/aws-sdk/lib/state_machine.js:26:10\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:38:9)\n at Request.<anonymous> (/home/yellowtent/box/node_modules/aws-sdk/lib/request.js:688:12)","name":"BoxError","reason":"External Error","details":{},"message":"Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)"}}
        [no timestamp]  Error copying archoslinux-backup/snapshot/app_070963ae-8ef3-4bcb-bab3-7ca671f4a72b/fsmetadata.json (148 bytes): InternalError InternalError: We encountered an internal error, please try again.: cause(EOF)
        • archosA
          archosA
          archos
          I've tried manual backups several times, but each time I end up with the same error. I would really appreciate any help or advice. Thank you very much for the information.
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying with concurrency of 110"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying files from 0-4"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying config.json"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying data/env"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying fsmetadata.json"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Copying postgresqldump"}
          May 25 08:12:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (1) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:12:30 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (2) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:12:50 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (3) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:13:10 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (4) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:13:31 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (5) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:13:51 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (6) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:14:11 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (7) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:14:31 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (8) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          May 25 08:14:51 box:tasks update 10025: {"percent":6.555555555555555,"message":"Retrying (9) copy of postgresqldump. Error: InternalError: We encountered an internal error, please try again.: cause(EOF) 500"}
          • archosA
            archosA
            archos
            I apologize for the previous question; the issue was apparently caused by the idrive-e2 provider, as I experienced it on other servers with Cloudron as well. The backup is now working again, except for Matrix Synapse.
              @archos for bugs like Synapse, I am fixing our code to have better logs . Off late, there's been a bunch of backup related issues. It's not clear (yet) whether this is some bug in node or some node module or the upstream provider. The error happens randomly and the logs are not helpful. I will update this post when I have a patch.
                Closed due to inactivity
                Note: A lot has changed for backups and will change even further with Cloudron 9.
                If this issue persists please reopen this as a new issue.
                • jadudmJ jadudm referenced this topic on
