  3. Cloudron Installation on a fresh AWS does not work
awsinstallation
5 Posts 2 Posters 1.5k Views 2 Watching
  • V Offline
    V Offline
    vaibhav
    I have created a new VPS on AWS lightsail (2 GB RAM, 2 vCPUs, 60 GB SSD) 22.04 Ubuntu
    I have run the commands as mentioned individually with sudo
    chmod +x ./cloudron-setup
    ./cloudron-setup
    Nginx is running.
    I have opened all ports (temporarily)
    IP is 13.202.121.11
    Opening the same IP on https does not work for initial config
    running the below command
    tail -f /var/log/cloudron-setup.log
    says:
    # the nologin will also disable su/login. hardcoding uid helps in restoring
    if ! id yellowtent 2>/dev/null; then
        useradd --system --uid 808 --comment "Cloudron Box" --create-home --shell /usr/sbin/nol
    ogin yellowtent
    fi
    # add support user (no password, sudo)
    if ! id cloudron-support 2>/dev/null; then
        useradd --system --comment "Cloudron Support (support@cloudron.io)" --create-home --no-
    user-group --shell /bin/bash cloudron-support
    fi
    I have tried destroying the VPS and redoing only to get the same result.
    Please help.
      @vaibhav you mean the setup script just hangs? What does it show in the main terminal where you ran the setup script?
      • V Offline
        V Offline
        vaibhav
        I managed to fix it @girish.
        Applying the commands in the terminal did not work.
        I then asked AWS to apply these instructions while creating a new instance.
        Worked like a charm.
        But in hindsight, my original attempts should have worked. I dunno why it didn't.
        • V Offline
          V Offline
          vaibhav
          I have since deleted those other stuck VPS instances.
          • V Offline
            V Offline
            vaibhav
            Setup script hanged in the earlier cases.
