  2. Immich
  3. Storage management in Immich?
Scheduled Pinned Locked Moved Immich
47 Posts 9 Posters 31.3k Views 9 Watching
  • perelinP
    perelinP
    perelin
    Ah, got it. Tried, didnt do anything. But the whole mounted share already had like 777 permissions throughout:
    drwxrwxrwx 2 808 808 0 May 21 08:56 immich/
      oh right 😕 well you will hit other side-effects then with apps if the filesystem is not actually support those features. This is one of the reasons, we only allow to move the app itself onto very specific filesystems like xfs and ext4. Not sure what can be done if CIFS with hetzner does not allow this. Or maybe you can investigate if you setup the mountpoint manually on the system with other mount options?
      • perelinP
        perelinP
        perelin
        Yup, I guess I will experiment a bit with the mount options available. Will report back here if I find something that works, thx!
        • perelinP
          perelinP
          perelin
          Footnote: sadly Immich already decided to not support setups where utime is not availble: https://github.com/immich-app/immich/issues/14005
          • perelinP
            perelinP
            perelin
            @nebulon so, after some trials this works for me:
            • mounted my Storagebox as webdav share on the Cloudron host system in fstab by hand
            • added that share as a Filesystem Mountpoint Volume in Cloudron
            • clean Immich install
            • attached that Volume as a Mount to Immich in Immich Storage options
            • moved the Immich data directory to a subdirectory on that Mount in Immich Storage option
            See any issues that could come up? Mounting things by hand in fstab is fine for Cloudron?
              Mounting by hand is fine. I don't know about the stability of a webdav mountpoint in linux though. How are you mounting it?
              • M
                makemrproper
                wrote on last edited by makemrproper
                #47
                I just stumbled across this problem too.
                **As a user: I need MASSIVE storage, 2tb+ per user for upload to Immich feature, which works really great and also really great while on Cloudron. Therefore sshfs straight to my backup server is the best course of action.
                As a user I don't care about backup of the data I have uploaded to Immich. I am already backing up to MS Onedrive, Google Photos, and Immich will be the third backup location.**
                I need to make Immich use an SSHFS mounted volume.
                I will have to rely on manual mount of it instead, and make Cloudron believe it is a local folder. I really wanted to use the neat SSHFS mount feature in volumes tho.
                Why SSHFS. Well NFS could work, but I hate the way NFS locks up and catastrophically fails and locks up the processes that have a lock in the NFS files/folders.
                edit:
                This didn't work. See support thread on adding volumes, if interested https://forum.cloudron.io/topic/13856/trying-to-add-an-sshfs-mounted-location-as-a-regular-file-type-volume-in-cloudron
                Cloudron fan
                Paying Customer
                • M makemrproper referenced this topic on
