  3. Bug: When adding of a volume fails, docker container creation fails, removal of old volume impossible
volumesrepair
6 Posts 3 Posters 2.4k Views 3 Watching
  • necrevistonnezrN
    necrevistonnezrN
    Scenario:
    • I had a volume "Calibre" set up as filesystem with the path /media/SG2TB/M/Calibre but I changed the path afterwards to /media/SG2TB/M/Books.
    • Tried to include the volume in the Komga app.
    • I get an error BoxError: (HTTP code 400) bad parameter - invalid mount config for type "bind": bind source path does not exist: /media/SG2TB/M/Calibre
    • Now I can't remove the (wrong) Volume in the Komga app view as the Save button in the storage tab is greyed out:
    • I can't remove the Volume in the Volume setting as it is "in use":
    • Restart is also greyed out:
    • I don't have a backup as I just installed the app.
    What can I do?
    • J
      Are you able to just uninstall the app? You can import data into the new app from backup. But looks like a bug that needs to be fixed.
        necrevistonnezrN
        necrevistonnezrN
        @joseph said in Bug: When adding of a volume fails, docker container creation fails, removal of old volume impossible:
          Scenario:
          What can I do?
          @necrevistonnezr said in Bug: When adding of a volume fails, docker container creation fails, removal of old volume impossible:
          Trying to reproduce this... Do you mean here that you deleted the Old volume and added a new Volume? Because you cannot change the path of 'filesystem' volumes.
            nvm, I reproduced it. If you change the path behind Cloudron's back, it doesn't work. I think it's correct to error since that path doesn't exist anymore. But anyway quick fix is: simple create empty /media/SG2TB/M/Calibre on the server and then Retry configure will work.
            After it comes up, remove the mount from the app, delete the volume, add new volume with correct path, add mount into app...
              necrevistonnezrN
              necrevistonnezrN
              @girish said in Bug: When adding of a volume fails, docker container creation fails, removal of old volume impossible:
              That's what I did, I went behind Cloudron's back 😉
              ... and didn't think of the obvious solution presented by you! Thank you.
