  2. Chatwoot
  3. Chatwoot 1.36.1 Upgrade Issue
Scheduled Pinned Locked Moved Solved Chatwoot
15 Posts 7 Posters 3.6k Views 7 Watching
  • C Offline
    C Offline
    cleveradmin
    It appears the database crashes during upgrade from 1.35.0 to 1.36.1. Here is what we see:
    => Sourcing /app/data/env.sh
    Feb 28 16:21:22 => Starting chatwoot
    Feb 28 16:21:22 => Upgrading existing db
    Feb 28 16:21:30 => Healtheck error: Error: connect ECONNREFUSED 172.18.20.35:3000
    Feb 28 16:21:36 I, [2025-02-28T23:21:36.197228 #10] INFO -- : [rake ip_lookup:setup] IP_LOOKUP_API_KEY empty. Skipping geoip database setup
    Feb 28 16:21:37 I, [2025-02-28T23:21:37.247106 #10] INFO -- : Migrating to CreateCaptainTables (20250104200055)
    Feb 28 16:21:37 == 20250104200055 CreateCaptainTables: migrating ==============================
    Feb 28 16:21:37 -- extension_enabled?("vector")
    Feb 28 16:21:37 -> 0.0176s
    Feb 28 16:21:37 -- enable_extension("vector")
    Feb 28 16:21:37 WARNING: terminating connection because of crash of another server process
    Feb 28 16:21:37 DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
    Feb 28 16:21:37 HINT: In a moment you should be able to reconnect to the database and repeat your command.
    Feb 28 16:21:37 rails aborted!
    Feb 28 16:21:37 ActiveRecord::ConnectionNotEstablished: connection to server at "fd00:c107:d509::5", port 5432 failed: FATAL: the database system is in recovery mode (ActiveRecord::ConnectionNotEstablished)
    Feb 28 16:21:37 connection to server at "172.18.30.2", port 5432 failed: FATAL: the database system is in recovery mode
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>' Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in each'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 PG::ConnectionBad: connection to server at "fd00:c107:d509::5", port 5432 failed: FATAL: the database system is in recovery mode (PG::ConnectionBad) Feb 28 16:21:37 connection to server at "172.18.30.2", port 5432 failed: FATAL: the database system is in recovery mode Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in each' Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (ActiveRecord::StatementInvalid) Feb 28 16:21:37 This probably means the server terminated abnormally Feb 28 16:21:37 before or while processing the request. Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>'
    Feb 28 16:21:37 PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (PG::ConnectionBad)
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 ActiveRecord::ConnectionNotEstablished: connection to server at "fd00:c107:d509::5", port 5432 failed: FATAL: the database system is in recovery mode (ActiveRecord::ConnectionNotEstablished) Feb 28 16:21:37 connection to server at "172.18.30.2", port 5432 failed: FATAL: the database system is in recovery mode Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQsocket() can't get socket descriptor (ActiveRecord::StatementInvalid) Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>'
    Feb 28 16:21:37 PG::ConnectionBad: PQsocket() can't get socket descriptor (PG::ConnectionBad)
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 StandardError: Failed to enable 'vector' extension. Read more at https://chwt.app/v4/migration (StandardError) Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:30:in rescue in setup_vector_extension'
    Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:27:in setup_vector_extension' Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:5:in up'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in block (2 levels) in <main>' Feb 28 16:21:37 2025-02-28T23:21:37Z Feb 28 16:21:37 Caused by: Feb 28 16:21:37 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (ActiveRecord::StatementInvalid) Feb 28 16:21:37 This probably means the server terminated abnormally Feb 28 16:21:37 before or while processing the request. Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:28:in setup_vector_extension'
    Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:5:in up' Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:26:in block (3 levels) in <main>'
    Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:28:in setup_vector_extension' Feb 28 16:21:37 /app/code/db/migrate/20250104200055_create_captain_tables.rb:5:in up'
    Feb 28 16:21:37 /app/code/lib/tasks/db_enhancements.rake:18:in `block (2 levels) in <main>'
    Feb 28 16:21:37 Tasks: TOP => db:migrate
    Feb 28 16:21:37 (See full trace by running task with --trace)
    • C Offline
      C Offline
      cleveradmin
      We restored from backup to 1.35.0 and it is working again. Have not attempted the upgrade again.
      • BrutalBirdieB Offline
        Please format your logs in a code block like
        your code goes here
        Resulting in
        your code goes here
        Make it less difficult for me and everyone's eyes to read your logs 😉
          Did the app or the Postgres service maybe run out of memory? 🤔 resulting to this issue?
            @cleveradmin can you try to clone the app instance and then perform the update on the cloned one? This way we can see if it is reproducible.
            • M Offline
              M Offline
              mazarian
              I am having a similar error in my logs, but it's happening well after the upgrade.
              Mar 18 10:06:07 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:06:17 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:06:23 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:06:33 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:06:43 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:06:53 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:06:54 => Sourcing /app/data/env.sh
              Mar 18 10:06:54 => Starting chatwoot
              Mar 18 10:06:54 => Upgrading existing db
              Mar 18 10:06:56 I, [2025-03-18T17:06:56.956461 #10] INFO -- : [rake ip_lookup:setup] IP_LOOKUP_API_KEY empty. Skipping geoip database setup
              Mar 18 10:06:57 2025-03-18T17:06:57Z
              Mar 18 10:06:57 (See full trace by running task with --trace)
              Mar 18 10:06:57 /app/code/db/schema.rb:134:in `block in <main>'
              Mar 18 10:06:57 /app/code/db/schema.rb:13:in `<main>'
              Mar 18 10:06:57 /app/code/lib/tasks/db_enhancements.rake:18:in `block (2 levels) in <main>'
              Mar 18 10:06:57 /app/code/lib/tasks/db_enhancements.rake:18:in `each'
              Mar 18 10:06:57 /app/code/lib/tasks/db_enhancements.rake:22:in `block (3 levels) in <main>'
              Mar 18 10:06:57 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (ActiveRecord::StatementInvalid)
              Mar 18 10:06:57 Caused by:
              Mar 18 10:06:57 PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (PG::ConnectionBad)
              Mar 18 10:06:57 Tasks: TOP => db:chatwoot_prepare
              Mar 18 10:06:57 This probably means the server terminated abnormally
              Mar 18 10:06:57 before or while processing the request.
              Mar 18 10:06:57 rails aborted!
              Mar 18 10:07:07 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:07:17 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:07:26 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:07:33 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:07:43 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:07:43 BoxError: Unknown install command in apptask:error
              Mar 18 10:07:53 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:07:57 => Starting chatwoot
              Mar 18 10:07:57 => Sourcing /app/data/env.sh
              Mar 18 10:07:57 => Upgrading existing db
              Mar 18 10:08:00 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.185:3000
              Mar 18 10:08:00 I, [2025-03-18T17:08:00.416259 #10] INFO -- : [rake ip_lookup:setup] IP_LOOKUP_API_KEY empty. Skipping geoip database setup
              Mar 18 10:08:00 rails aborted!
              Mar 18 10:08:00 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (ActiveRecord::StatementInvalid)
              Mar 18 10:08:00 This probably means the server terminated abnormally
              Mar 18 10:08:00 before or while processing the request.
              Mar 18 10:08:00 /app/code/db/schema.rb:134:in `block in <main>'
              Mar 18 10:08:00 /app/code/db/schema.rb:13:in `<main>'
              Mar 18 10:08:00 /app/code/lib/tasks/db_enhancements.rake:22:in `block (3 levels) in <main>'
              Mar 18 10:08:00 /app/code/lib/tasks/db_enhancements.rake:18:in `each'
              Mar 18 10:08:00 /app/code/lib/tasks/db_enhancements.rake:18:in `block (2 levels) in <main>'
              Mar 18 10:08:00 2025-03-18T17:08:00Z
              Mar 18 10:08:00 Caused by:
              Mar 18 10:08:00 PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (PG::ConnectionBad)
              Mar 18 10:08:00 Tasks: TOP => db:chatwoot_prepare
              Mar 18 10:08:00 (See full trace by running task with --trace)
              Mar 18 10:08:17 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:08:27 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:08:33 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:08:43 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:08:53 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:09:01 => Starting chatwoot
              Mar 18 10:09:01 => Sourcing /app/data/env.sh
              Mar 18 10:09:01 => Upgrading existing db
              Mar 18 10:09:03 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.185:3000
              Mar 18 10:09:03 I, [2025-03-18T17:09:03.629615 #10] INFO -- : [rake ip_lookup:setup] IP_LOOKUP_API_KEY empty. Skipping geoip database setup
              Mar 18 10:09:04 rails aborted!
              Mar 18 10:09:04 ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (ActiveRecord::StatementInvalid)
              Mar 18 10:09:04 This probably means the server terminated abnormally
              Mar 18 10:09:04 before or while processing the request.
              Mar 18 10:09:04 /app/code/db/schema.rb:134:in `block in <main>'
              Mar 18 10:09:04 /app/code/db/schema.rb:13:in `<main>'
              Mar 18 10:09:04 /app/code/lib/tasks/db_enhancements.rake:22:in `block (3 levels) in <main>'
              Mar 18 10:09:04 /app/code/lib/tasks/db_enhancements.rake:18:in `each'
              Mar 18 10:09:04 /app/code/lib/tasks/db_enhancements.rake:18:in `block (2 levels) in <main>'
              Mar 18 10:09:04 2025-03-18T17:09:04Z
              Mar 18 10:09:04 Caused by:
              Mar 18 10:09:04 PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly (PG::ConnectionBad)
              Mar 18 10:09:04 Tasks: TOP => db:chatwoot_prepare
              Mar 18 10:09:04 (See full trace by running task with --trace)
              Mar 18 10:09:17 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:09:27 => Healtheck error: Error: Timeout of 7000ms exceeded
              Mar 18 10:09:33 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:09:43 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:09:53 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              Mar 18 10:10:03 => Healtheck error: Error: connect EHOSTUNREACH 172.18.19.185:3000
              I tried recovering from backup and cloning and am getting the following error:
              An error occurred during the clone operation: Addons Error: Unexpected response code or HTTP error when piping /home/yellowtent/appsdata/e2f314e0-389e-4c1b-8e80-9852e13db8e3/postgresqldump to http://172.18.30.2:3000/databases/dbe2f314e0389e4c1b8e809852e13db8e3/restore?access_token=b637659aed0a708f188d2902fc267163718b8c6777cd722433926b0654ff03c7c2fc782f7c39a559f0d1954f031c7215eb96ebf6bc759500e2419d84607396d249c157dc7a7db537926351f20ae6a23261db0a55c93e07a278161db6c2e7f4fdd04756ff7cc1cd30bd67096101d9b83b643ebf91abf5f2e3a2026dbd93d1ae6b&username=usere2f314e0389e4c1b8e809852e13db8e3: status 500 complete false
              Any help would greatly be appreciated!
                Is your postgres service up and running? Since it returned a 500 status code during database import, it should have error messages in its logs.
                • M Offline
                  M Offline
                  mazarian
                  I'm not quite sure how to check - I am only able to get into recovery mode and when going into the terminal and pressing the Postgres button, I see this:
                  root@fa89594f-7176-4a81-9c25-1686af1e50da:/app/code# PGPASSWORD=${CLOUDRON_POSTGRESQL_PASSWORD} psql -h ${CLOUDRON_POSTGRESQL_HOST} -p ${CLOUDRON_POSTGRESQL_PORT} -U ${CLOUDRON_POSTGRESQL_USERNAME} -d ${CLOUDRON_POSTGRESQL_DATABASE}
                  psql (14.9 (Ubuntu 14.9-0ubuntu0.22.04.1), server 16.6 (Ubuntu 16.6-0ubuntu0.24.04.1))
                  WARNING: psql major version 14, server major version 16.
                           Some psql features might not work.
                  Type "help" for help.
                  dbfa89594f71764a819c251686af1e50da=>
                  • M mazarian
                    andreasduerenA Online
                    andreasdueren
                    @mazarian Go to https://my.tld.com/#/services and increase memory if necessary and/or reboot that service
                    M 1 Reply Last reply
                      M Offline
                      M Offline
                      mazarian
                      @andreasdueren and @nebulon thank you both for your replies!
                      I just looked at my services, and things looked ok. Graphite was at 84% and I doubled the memory. I also doubled my Postgres memory and Redis memory (for the affected Chatwoot app) but none of those things seemed to help.
                      • M Offline
                        M Offline
                        mazarian
                        It's also odd- when I try switching between recovery mode off and on, Redis throws errors and I have to restart the service. But doing so doesn't allow me to start the application outside of recovery mode and still in the error logs, I see the same PG errors.
                        • M Offline
                          M Offline
                          mazarian
                          Just wanted to add - it seems like I am having to restore from backup for many of my apps. All of the restores are working except for Chatwoot. It seems like something went wrong after the upgrade to Cloudron 8.3.
                          S 1 Reply Last reply
                          • J Online
                            J Online
                            @mazarian if you can write to support@cloudron.io, we can take a look . it seems a few hit this issue with restoring chatwoot on the recent postgres. however, we haven't been to reproduce it.
                            • M mazarian
                              S Offline
                              S Offline
                              stevespaw
                              @mazarian said in Chatwoot 1.36.1 Upgrade Issue:
                              Same issue here!
                              • S Offline
                                S Offline
                                stevespaw
                                8.3.1 seems to have fixed this issue! Thanks team Cloudron!
