  2. Nextcloud
  3. Collabora Connection Error after changing domain name
8 Posts 3 Posters 2.7k Views 3 Watching
  • L
    leemuljadi
    and somehow it is stuck and cannot be edited.
    • L leemuljadi
      Hello @leemuljadi
      Since you need to whitelist the domain / URL in Collabora, changing the Domain of Nextcloud can lead to this issue.
      Please check the documentation => https://docs.cloudron.io/packages/collabora/#setup and your Collabora setup if your new Domain for Nextcloud is allowed.
      • L
        leemuljadi
        thanks @james
        somehow this doesn't work, the option and text field of the url still grey out and not selectable
          @leemuljadi this seems missing in the screenshot.
          Could you please send a new one including the field in question?
          • L
            leemuljadi
            wrote on last edited by leemuljadi
            @james
              Hello @leemuljadi
              Have you tried to select Use a demo server if selecting this works and maybe after that you can select Use your own server again and edit that field.
              • L
                leemuljadi
                @james unfortunately. can. even. click. it. its. greyed. out
                  that seems odd that the UI elements (like the radio buttons in the first place) are disabled. This seems like a Nextcloud bug. Maybe check your browser console to see if some related JS error it thrown and maybe try another browser, just to rule out the obvious. I can't reproduce it here.
