  3. Transmission + OpenVPN/WireGuard tunnel
1 Posts 1 Posters 635 Views 1 Watching
  • T
    T
    tachy
    • Main Page: https://haugene.github.io/docker-transmission-openvpn/
    • Git: https://github.com/haugene/docker-transmission-openvpn
    • Licence: GPL 3
    • Docker: Yes
    • Summary:
      If you want to download via Torrent without leaking your IP, an outgoing VPN is mandatory. But maybe you don't want all your traffic going through the VPN.
      This project solves it all : Transmission packaged with OpenVPN & WireGuard and easy configuration whatever VPN provider you are using.
      Would be incredible to see this integrated in Cloudron package.
    • Notes :
      Might be difficult to package as some paths are hardcoded (OpenVPN paths especially) and need read/write permissions.
