  2. EspoCRM
  3. EspoCRM Extension Uninstall/Upgrade issue
Scheduled Pinned Locked Moved EspoCRM
9 Posts 2 Posters 2.0k Views 2 Watching
  • C Offline
    C Offline
    creative567145
    We couldn't find any info on how to Upgrade an extension, so here is the process we have done:
    (Extension name: Advanced Pack)
    1. We tried to upload it (the new version on top of the already installed version) directly in EspoCRM, and we got this error:
      Error 500
      Permission denied to delete files.
    2. In EspoCRM we tried to Uninstall the extension, but we got this error:
      Error 500
    3. We followed the steps listed here:
      https://docs.cloudron.io/packages/espocrm/#uninstalling-extension
      Command:
      php command.php extension -u --name="Advanced Pack"
    PHP Warning:  mkdir(): File exists in /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php on line 517
    PHP Warning:  mkdir(): No such file or directory in /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php on line 517
    PHP Fatal error:  Uncaught Espo\Core\Utils\File\Exceptions\PermissionError: Permission denied: unable to create a folder on the server data/cache/application in /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php:654
    Stack trace:
    #0 /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php(298): Espo\Core\Utils\File\Manager->checkCreateFile()
    #1 /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php(412): Espo\Core\Utils\File\Manager->putContents()
    #2 /app/code/9.2.2/application/Espo/Core/Utils/DataCache.php(82): Espo\Core\Utils\File\Manager->putPhpContents()
    #3 /app/code/9.2.2/application/Espo/Core/Utils/Module.php(101): Espo\Core\Utils\DataCache->store()
    #4 /app/code/9.2.2/application/Espo/Core/Utils/Module.php(71): Espo\Core\Utils\Module->init()
    #5 /app/code/9.2.2/application/Espo/Core/Utils/Module.php(120): Espo\Core\Utils\Module->get()
    #6 [internal function]: Espo\Core\Utils\Module->Espo\Core\Utils\{closure}()
    #7 /app/code/9.2.2/application/Espo/Core/Utils/Module.php(119): usort()
    #8 /app/code/9.2.2/application/Espo/Core/Binding/EspoBindingLoader.php(42): Espo\Core\Utils\Module->getOrderedList()
    #9 /app/code/9.2.2/application/Espo/Core/Container/ContainerBuilder.php(210): Espo\Core\Binding\EspoBindingLoader->__construct()
    #10 /app/code/9.2.2/application/Espo/Core/Application.php(66): Espo\Core\Container\ContainerBuilder->build()
    #11 /app/code/9.2.2/application/Espo/Core/Application.php(57): Espo\Core\Application->initContainer()
    #12 /app/code/9.2.2/command.php(35): Espo\Core\Application->__construct()
    #13 {main}
      thrown in /app/code/9.2.2/application/Espo/Core/Utils/File/Manager.php on line 654
    1. We tried to do it with the Recovery turned off and here is the result:
    php command.php extension -l
    Extensions:
     Version: 3.11.7
     Installed: yes
    root@a039099f-5cea-4d45-9e1a-b2ddf13a2a71:/app/code/9.2.2# php command.php extension -u --name="Advanced Pack"
    Uninstalling... Do not close the terminal. This may take a while...
    Currently we aren't able to Uninstall or Upgrade the current Extension.
    Perhaps there is some bug with the current EspoCRM version or some other reason?
    • jamesJ Online
      jamesJ Online
      Hello @creative567145
      Thanks for reporting, I will look into it.
      Can you please share your current Cloudron Version, Cloudron App Version of EspoCRM and the Extension with its Version.
      C 1 Reply Last reply
        C Offline
        C Offline
        creative567145
        @james Thank you for the fast response
        Cloudron version: v8.3.2 (Ubuntu 24.04.3 LTS) (I have included the OS for just in case)
        EspoCRM version: Espo CRM 9.2.2
        Package Version: com.espocrm.cloudronapp@2.19.1
        Advanced Pack - Extension version: advanced-pack-3.11.7
        • jamesJ Online
          jamesJ Online
          Since Advanced Pack is a paid extension I am unable to start reproducing the issue with this extension.
          Do you have another extension for EspoCRM that is free and has the same issues?
          • C Offline
            C Offline
            creative567145
            wrote on last edited by creative567145
            Since only the person that has paid for it is able to get updates, I'll send the file to you in the private chat (for testing purposes)
            • jamesJ Online
              jamesJ Online
              I was able to reproduce this issue.
              Reproduction
              When the app is in recovery mode some symlinks that filled on runtime are missing.
              The error gave the right detail:
              When you start the recovery mode and go into the web terminal and do:
              ls -lah data/
              total 36K
              drwxr-xr-x 5 www-data www-data 4.0K Oct 14 10:06 .
              drwxr-xr-x 8 www-data www-data 4.0K Oct 14 09:44 ..
              drwxrwxr-x 3 www-data www-data 4.0K Oct 14 09:57 .backup
              lrwxrwxrwx 1 www-data www-data   18 Oct 14 10:06 cache -> /run/espocrm/cache
              -rw-r--r-- 1 www-data www-data 1.3K Oct 14 10:06 config-internal.php
              -rw-r--r-- 1 www-data www-data 9.9K Oct 14 10:06 config.php
              lrwxrwxrwx 1 www-data www-data   17 Oct 14 10:06 logs -> /run/espocrm/logs
              drwxrwxr-x 2 www-data www-data 4.0K Oct 14 10:06 tmp
              drwxrwxr-x 3 www-data www-data 4.0K Oct 14 09:57 upload
              Since the color is missing in text here also a screenshot.
              The red color on cache and logs indicate that the target of the symlink does not exist.
              So we need to create this manually with:
              mkdir -p /run/espocrm/cache
              mkdir -p /run/espocrm/logs
              Or even better start EspoCRM once and quit it with crtl+c.
              /app/pkg/start.sh
              Now I can run:
              Extensions:
               Version: 3.11.7
               Installed: yes
              and uninstall it with:
              Another error Permission denied to delete files.
              Let's see the log:
              cat /run/espocrm/logs/espo-2025-10-14.log
              [2025-10-14 10:23:35] WARNING: E_WARNING: rmdir(client/custom): Not a directory
              [2025-10-14 10:23:36] WARNING: E_WARNING: rmdir(custom): Not a directory
              Since client/custom and custom are symlinks and not directories maybe the php code fails here.
              And after some PHP code debugging I found the offender.
              Solution - manual patching in recovery mode
              You need to edit the following file at line 704 application/Espo/Core/Utils/File/Manager.php:
              # Open the file at line 704
              nano +704 application/Espo/Core/Utils/File/Manager.php
              Edit the if statement to:
              if (is_dir($dirPath) && is_writable($dirPath) && is_link($dirPath) === false)
              Save and close the file and now you can run:
              Disable the recovery mode and when checking the Admin UI for Extensions it is uninstalled.
              • C Offline
                C Offline
                creative567145
                Thank you @james
                We have performed the steps and it's working
                Here are the steps in detail (for noobs like me to replicate it):
                1. Log in Cloudron + select EspoCRM + Click on the Repair tab: Enable Recovery Mode
                2. Click: Terminal
                3. Copy paste this:
                4. This is the original line:
                  if (is_dir($dirPath) && is_writable($dirPath)) {
                5. Change it to this:
                  if (is_dir($dirPath) && is_writable($dirPath) && is_link($dirPath) === false) {
                6. On the keyboard click: CTRL + X
                  Then click to confirm: Y
                7. Copy paste this:
                8. Close the Terminal window
                9. Click to Disable the Recovery mode
                  there is no need to Restart EspoCRM
                10. Log in EspoCRM as admin >>> extensions
                • 1 more step to update the Extension:
                  Since the old Extension version was uninstalled, now we upload the new version + click Install
                @james We noticed that the change in the Manager.php file is not permanent.
                So this means that we would have to go through all these steps each time an Extension update is required.
                Business-wise, this will reduce the client-retention rate of the Cloudron userbase. Especially those that aren't tech experienced.
                Ideally the extension updates would be performed by the EspoCRM admin just uploading the new version inside EspoCRM (UI) and it replaces the old version.
                Is it possible for the Cloudron team some day to push an update to the EspoCRM package that applies this change permanently?
                • jamesJ Online
                  jamesJ Online
                  We have already given notice to upstream about the issue and a discussion was started how to handle symlinks.
                  So there might be a solid solution comming from upstream.
                    C Offline
                    C Offline
                    creative567145
                    Thank you @james , much appreciated
