  2. Package development
  3. Ente for cloudron, help for testing wanted.
36 Posts 8 Posters 8.9k Views 10 Watching
  • andreasduerenA
    andreasduerenA
    andreasdueren
    I have a working package of ente for cloudron.
    You can use my docker image with andreasdueren/ente-cloudron --tag 0.4.5
    Currently these are the limitations/quirks:
    • admins need to manually set up Aliases for the following sub domains: family, albums, cast, auth and accounts
    • the actual user IP addresses aren't passed into the log by caddy. Right now the Dockerfile installs the Debian-packaged Caddy that ships with cloudron/base:5.0.0, which is why the optional modules aren’t present. If we want http.handlers.realip, we would need to build Caddy ourselves and bundle that binary instead of apt-getting the stock one.
    • I have only tested this package with one s3 zone. Replication should be working but I haven't had time to test it.
    • In general this application relies heavily on the CLI for user management. This includes increasing storage quota. It should work, but again haven't had much time to test.
    • andreasduerenA
      andreasduerenA
      andreasdueren
      I think this is ready for an unstable release: andreasdueren/ente-cloudron:0.5.3
      I tested and fixed:
      • Upload with the mobile app
      • The CLI/increasing storage quota
      • httpPorts feature for automatic sub domain setup
      • necrevistonnezrN
        necrevistonnezrN
        Super Fan
        Is the manual setup of subdomains still required after https://forum.cloudron.io/post/114771?
          andreasduerenA
          andreasduerenA
          andreasdueren
          @necrevistonnezr Nope
          • andreasduerenA
            andreasduerenA
            andreasdueren
            Updated Ente Package: andreasdueren/ente-cloudron:0.5.5
            • Implemented replication across three buckets
            Tested with the following providers:
            Primary: Backblaze, Secondary: Hetzner Object Sorage, Glacier: Scaleway
            One important consideration: The cold bucket needs to support the GLACIER class Ente tries to use. So either point S3_COLD_* at an actual Glacier-capable object store (like Scaleway’s cold tier) or switch the app to local buckets mode so the start script configures Museum with are_local_buckets: true / use_path_style_urls: true, which causes the replication controller to skip the Glacier storage class.
            • andreasduerenA
              andreasduerenA
              andreasdueren
              Updated Ente Package: andreasdueren/ente-cloudron:0.5.6
              • The cloudron image now bundles the full Families frontend and rewrites its links toward your self-hosted origin, includes billing-plan JSON so Museum can resolve subscriptions without manual DB edits. Families email invitations were patched to read apps.family (so they link to family.<your-domain> instead of family.ente.io).
              • andreasduerenA
                andreasduerenA
                andreasdueren
                Updated Ente Package: andreasdueren/ente-cloudron:0.5.7
                • Passkeys and Accounts now load properly.
                • Share/embed/payments bundles ship with the image, their URLs are rewritten, and Caddy serves them via dedicated hosts and the manifest exposes those hostnames so you can configure them.
                • timconsidineT
                  @andreasdueren you're working miracles ! Well done and thank you.
                    andreasduerenA
                    andreasduerenA
                    andreasdueren
                    @timconsidine lol don’t know about that
                    • andreasduerenA
                      andreasduerenA
                      andreasdueren
                      Updated Ente Package to use latest upstream images: andreasdueren/ente-cloudron:0.5.9
                      Still haven't been able to get Ente Locker working but the documentation is basically non-existant.
                      • sponchS
                        sponchS
                        sponch
                        hey @andreasdueren how can I add your image to be used in CLoudron?
                          Hello @sponch
                          You will need the Cloudron CLI.
                          When you have installed the Cloudron CLI and authentificated yourself against the Cloudron server you wish to use, you can run the following commands:
                          git clone https://git.due.ren/andreas/ente-cloudron.git
                          cd ente-cloudron
                          cloudron install --location ente --image andreasdueren/ente-cloudron:0.5.9
                          or you can use @timconsidine app installer tool: https://ccai.appx.uk/
                          sponchS 1 Reply Last reply
                            Hello @sponch
                            cd ente-cloudron
                            sponchS
                            sponchS
                            sponch
                            @james Hi, thanks a lot..just going through configuration of Ente... 😧
                            • sponchS
                              sponchS
                              sponch
                              up and running, can't find a possibility in their iOS App to connect to custom instances.
                              • sponchS sponch
                                andreasduerenA
                                andreasduerenA
                                andreasdueren
                                @sponch You have to tap the onboarding screen 7 times and then enter your ente server
                                sponchS robiR 2 Replies Last reply
                                  sponchS
                                  sponchS
                                  sponch
                                  @andreasdueren OMG...thanks
                                  andreasduerenA 2 Replies Last reply
                                  • sponchS sponch
                                    andreasduerenA
                                    andreasduerenA
                                    andreasdueren
                                    @sponch No problem! 🙂
                                      @andreasdueren LOL as if in frustration.. OK 😂
                                      • sponchS sponch
                                        andreasduerenA
                                        andreasduerenA
                                        andreasdueren
                                        @sponch Is everything working?
                                        • andreasduerenA
                                          andreasduerenA
                                          andreasdueren
                                          Updated Ente Package: andreasdueren/ente-cloudron:0.6.1
                                          🔧 Fixes:
                                          • Ente Locker now works: public-locker was incorrectly pointing to the embed app — it now correctly points to the share app (apps/share), which is the actual Public Locker frontend. This fixes Locker redirecting to the photos app.
                                          Changes since 0.5.9:
                                          • v0.6.0 — Fresh build with latest upstream ente sources
                                          • Customize email footer for self-hosted instance (removes ente.io branding)
                                          • Redirect base domain to photos host
                                          • Fix Museum API matchers scoped to photos host
                                          • v0.6.1 — Fix public-locker → share URL (Locker fix)
                                          Upstream: https://github.com/ente-io/ente/commit/deb7314
