  2. Change Detection
  3. Cloudron deploying wrong/old code? is it possible?
Scheduled Pinned Locked Moved Change Detection
24 Posts 3 Posters 5.8k Views 3 Watching
  • D
    D
    dgtlmoon
    https://github.com/dgtlmoon/changedetection.io/issues/3576 this is kinda similar but the user reports it as solved
    • D
      D
      dgtlmoon
      let me verify an old tag install then upgrade...
      • D
        D
        dgtlmoon
        Tried old 0.45.9, - Plaintext test
        • Set up "mailto://me@localhost" on test SMTP server as "Global notification setting", and "Text" notification type
        • Watch: Added the time.php test with "system default" notification format
        shut down, switch to 0.50.38, start up, updates ran,
        SMTP test was OK no placeholders
        @imc67 can you email me your url-watches.json again? then i can compare what settings are different maybe
        imc67I 1 Reply Last reply
        • D dgtlmoon
          imc67I
          imc67I
          imc67
          translator Super Fan
          @dgtlmoon said in Cloudron deploying wrong/old code? is it possible?:
          just done so
