  2. MiroTalk
  3. MiroTalk SFU: Recording not possible?
51 Posts 4 Posters 5.5k Views 4 Watching
  • S
    S
    shrey
    Hi @nebulon @mirotalk-57bab571
    So, i'm still unable to boot up the app after setting RECORDING_ENABLED=true :
    Nov 15 09:36:54 node:fs:1364
    Nov 15 09:36:54 const result = binding.mkdir(
    Nov 15 09:36:54 ^
    Nov 15 09:36:54 2025-11-15T04:06:54Z
    Nov 15 09:36:54 Error: ENOENT: no such file or directory, mkdir '/app/code/app/rec/'
    Nov 15 09:36:54 at Object.mkdirSync (node:fs:1364:26)
    Nov 15 09:36:54 at Object.<anonymous> (/app/code/app/src/Server.js:280:12)
    Nov 15 09:36:54 at Module._compile (node:internal/modules/cjs/loader:1554:14)
    Nov 15 09:36:54 at Object..js (node:internal/modules/cjs/loader:1706:10)
    Nov 15 09:36:54 at Module.load (node:internal/modules/cjs/loader:1289:32)
    Nov 15 09:36:54 at Function._load (node:internal/modules/cjs/loader:1108:12)
    Nov 15 09:36:54 at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    Nov 15 09:36:54 at wrapModuleLoad (node:internal/modules/cjs/loader:220:24)
    Nov 15 09:36:54 at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:170:5)
    Nov 15 09:36:54 at node:internal/main/run_main_module:36:49 {
    Nov 15 09:36:54 errno: -2,
    Nov 15 09:36:54 code: 'ENOENT',
    Nov 15 09:36:54 syscall: 'mkdir',
    Nov 15 09:36:54 path: '/app/code/app/rec/'
    Nov 15 09:36:54 }
    Nov 15 09:36:54 Node.js v22.14.0
    Nov 15 09:36:54 \
    MiroTalkM 1 Reply Last reply
    • S shrey
      Nov 15 09:36:54 ^
      Nov 15 09:36:54 }
      Nov 15 09:36:54 \
      MiroTalkM
      MiroTalkM
      MiroTalk
      App Maintainer
      #22
      @shrey said in MiroTalk SFU: Recording not possible?:
      Forget the previous env configuration. In the latest Cloudron commit, recording is enabled by default, and the app/data path now appears to be automatically resolved as well.
      • S
        S
        shrey
        @mirotalk-57bab571
        I restarted the updated app, but i still get only this:
        No rec folder available, and no default recording taking place.
        • S
          S
          shrey
          wrote on last edited by shrey
          #24
          @mirotalk-57bab571
          It seems like 2 separate updated packages have been released for this.
          Just came across the 2nd one and updated the app again.
          1. The rec folder is now available in /app/data/
          2. All recordings are still being saved on the local device only. No server-side recording. No S3 recording.
          • S shrey
            @mirotalk-57bab571
            Hello @shrey
            I have just updated my Mirotalk SFU app and now the recordings are stored inside the Mirotalk SFU app in /app/data/rec/.
            Please share your /app/data/env file.
            With the updated app and a fresh installed app the recording works.
            In a meeting I can do:
            ls -lah /app/data/rec/
            total 5.2M
            drwxr-xr-x 2 cloudron cloudron 4.0K Nov 15 09:46 .
            drwxr-xr-x 3 cloudron cloudron 4.0K Nov 15 09:44 ..
            -rw-r--r-- 1 cloudron cloudron 5.2M Nov 15 09:46 Rec_09598YoungSpid_2025_11_15_10_45_32_e0005370-10dd-4487-a68e-cff4d94f274d.webm
            • S
              S
              shrey
              Hi @james , thanks for the screenshots. I can now see that there's a "Save on server" option in the UI, and it's working for me as well.
              Now, just S3 is left to work.
              My env file ->
              # Recording
              RECORDING_ENABLED=true                           # Enable recording functionality (true|false)
              RECORDING_UPLOAD_TO_S3=false                      # Upload recording to AWS S3 bucket [true/false]
              # AWS S3 Configuration
              AWS_S3_ENABLED=true                              # Enable AWS S3 storage (true|false)
              AWS_S3_BUCKET_NAME=<bucket-name>                       # Name of your S3 bucket (must exist)
              AWS_ACCESS_KEY_ID=<key-id>                                # AWS Access Key ID (leave empty for IAM roles)
              AWS_SECRET_ACCESS_KEY=<key-secret>                            # AWS Secret Access Key (leave empty for IAM roles)
              AWS_REGION=<region>                                   # AWS region (e.g., us-east-2, eu-west-2)
              AWS_S3_ENDPOINT=https://<region>.digitaloceanspaces.com
              Note: Although i didn't find the "AWS_S3_ENDPOINT" key in the env template, i configured it because it seems to work with most S3 client libraries, and is a necessity to be able to connect to S3 spaces other than AWS.
                Hello @shrey
                The library used in MiroTalk SFU for AWS/S3 is aws-sdk/client-s3.
                It seems MiroTalk SFU does not have the option to configure the endpoint.
                From the MiroTalk SFU Code handling the configuration:
                https://github.com/miroslavpejic85/mirotalksfu/blob/b2a41e597610524b259097d2e1b52674dda631c0/app/src/config.template.js#L948-L954
                        aws: {
                            enabled: process.env.AWS_S3_ENABLED === 'true',
                            accessKeyId: process.env.AWS_ACCESS_KEY_ID || 'your-access-key-id',
                            secretAccessKey: process.env.AWS_SECRET_ACCESS_KEY || 'your-secret-access-key',
                            region: process.env.AWS_REGION || 'us-east-2',
                            bucket: process.env.AWS_S3_BUCKET || 'mirotalk',
                Also in the server.js where the S3Client is initialized, the endpoint is never configured, thus using the default, resolving the endpoint from the AWS_REGION.
                https://github.com/miroslavpejic85/mirotalksfu/blob/b2a41e597610524b259097d2e1b52674dda631c0/app/src/Server.js#L297-L303
                const s3Client = new S3Client({
                    region: config?.integrations?.aws?.region, // Set your AWS region
                    credentials: {
                        accessKeyId: config?.integrations?.aws?.accessKeyId,
                        secretAccessKey: config?.integrations?.aws?.secretAccessKey,
                So we need to ask @mirotalk-57bab571 to add the option to configure the endpoint as well.
                Adding to that, when a non AWS endpoint is used, the option forcePathStyle: true might also be needed for the best compatibility with e.g. MinIO and most S3-compatible systems.
                @mirotalk-57bab571
                It is the weekend, please don't feel pressured or forced to work on the weekend.
                Would it be possible to add the option to configure the S3Client endpoint config and S3Client forcePathStyle config?
                  Hello @shrey
                          aws: {
                      credentials: {
                  @mirotalk-57bab571
                  MiroTalkM
                  MiroTalkM
                  MiroTalk
                  App Maintainer
                  @james said in MiroTalk SFU: Recording not possible?:
                  So the goal is to avoid hard-coding support only for AWS S3.
                  To extend the configuration so it also supports any S3-compatible storage (MinIO, Wasabi, DigitalOcean Spaces, etc.), i need to add the following to the .env file:
                  AWS_S3_ENDPOINT=                     # e.g., http://localhost:9000 for MinIO
                  AWS_S3_FORCE_PATH_STYLE=false        # Set to true for S3-compatible services
                  Then expose these values in config.js:
                  aws: {
                      endpoint: process.env.AWS_S3_ENDPOINT || '',
                      forcePathStyle: process.env.AWS_S3_FORCE_PATH_STYLE === 'true',
                  Finally, update the S3 client configuration in Server.js:
                      endpoint: config?.integrations?.aws?.endpoint || undefined,
                      forcePathStyle: config?.integrations?.aws?.forcePathStyle === true,
                  With this setup, the application continues to work with AWS S3 as it currently does, but can also switch to any S3-compatible service simply by adjusting environment variables and no additional code changes required.
                  Sounds good to me! @James just confirm.
                    Hello @mirotalk-57bab571
                    LGTM!
                    Maybe adding a doc string in the env to AWS_S3_ENDPOINT that if left empty it will use region to resolve it automatically.
                    • MiroTalkM
                      MiroTalkM
                      MiroTalk
                      App Maintainer
                      ✅ Implemented in MiroTalk SFU v.2.0.16
                      • Commit
                      • Build
                        I am running the following env file:
                        All config options at https://github.com/miroslavpejic85/mirotalksfu/blob/main/.env.template
                        PRESENTERS=admin@cloudron.local
                        EMAIL_SEND_TO=admin@cloudron.local
                        STATS_ENABLED=false
                        RECORDING_UPLOAD_TO_S3=true
                        AWS_S3_ENABLED=true
                        AWS_S3_ENDPOINT=https://minio-api.cloudron.dev
                        AWS_S3_BUCKET_NAME=sfu
                        AWS_S3_FORCE_PATH_STYLE=true
                        AWS_ACCESS_KEY_ID=LJQVOTFR3DZDG1QPOL0Y
                        AWS_SECRET_ACCESS_KEY=j6w8j73VF8NE9wzsi4aupJICTrn45I0MKIoYUCk9
                        This access key and secret have full access to all buckets.
                        Buckets are backup and sfu.
                        The backup bucket I used for testing for Cloudron Backups, which works.
                        But with MiroTalk SFU there seems to be an issue:
                        Nov 16 16:43:28 [11/16/2025, 15:43:28:847] [Server] [Upload] Saved Rec_13172BasicZebra_2025_11_16_16_43_23_f6ee8290-dcb8-44ec-b30e-dab24b4bae36.webm (0.07 MB) in 0.00s ''
                        Nov 16 16:43:30 [11/16/2025, 15:43:30:316] [Server] Rec Finalization error 'The specified bucket does not exist'
                        Without the AWS_S3_FORCE_PATH_STYLE variable I get:
                        Nov 16 16:44:56 [11/16/2025, 15:44:56:198] [Server] Rec Finalization error 'getaddrinfo ENOTFOUND mirotalk.minio-api.cloudron.dev'
                        Which would suggest that AWS_S3_BUCKET_NAME which I set to sfu is getting ignored and default mirotalk is used?
                        So I add the AWS_S3_FORCE_PATH_STYLE=true again and create a bucket named mirotalk.
                        Confirmed working.
                        Nov 16 16:49:29 [11/16/2025, 15:49:29:552] [Server] [Upload] Saved Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm (0.95 MB) in 0.01s ''
                        Nov 16 16:49:29 [11/16/2025, 15:49:29:702] [Server] [Upload] Saved Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm (0.20 MB) in 0.00s ''
                        Nov 16 16:49:30 [11/16/2025, 15:49:30:586] [Server] [Rec Finalization] done Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm in 0.32s {
                        Nov 16 16:49:30 success: true,
                        Nov 16 16:49:30 fileName: 'Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm',
                        Nov 16 16:49:30 key: 'recordings/13172BasicZebra/Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm'
                        Nov 16 16:49:30 }
                        Nov 16 16:49:30 [11/16/2025, 15:49:30:587] [Server] [Upload] File /app/data/rec/Rec_13172BasicZebra_2025_11_16_16_49_23_3e9ab0ce-5148-43b3-a827-e524537fd01b.webm removed from local after S3 upload ''
                        /app/data/env is:
                        STATS_ENABLED=false
                        AWS_S3_ENABLED=true
                        And I created a bucket named mirotalk.
                          I found the offending lines:
                          https://github.com/miroslavpejic85/mirotalksfu/blob/e59b24bb37a7b19560a03de1a5abb5fb79a2c6b4/app/src/config.template.js#L961
                          https://github.com/miroslavpejic85/mirotalksfu/blob/e59b24bb37a7b19560a03de1a5abb5fb79a2c6b4/app/src/Server.js#L1118
                                      const bucket = config?.integrations?.aws?.bucket;
                          This would mean the env would be AWS_S3_BUCKET and not AWS_S3_BUCKET_NAME.
                          Confirmed with this env
                          STATS_ENABLED=false
                          AWS_S3_ENABLED=true
                          AWS_S3_BUCKET=sfu
                          PR created @mirotalk-57bab571 https://github.com/miroslavpejic85/mirotalksfu/pull/228
                            STATS_ENABLED=false
                            AWS_S3_ENABLED=true
                            AWS_S3_BUCKET=sfu
                            MiroTalkM
                            MiroTalkM
                            MiroTalk
                            App Maintainer
                            Ops, you’re right, good catch! PR accepted. Thanks for confirming that everything works as expected. MiroTalk SFU can now upload recordings to any S3-compatible storage, not just AWS! 💪
                            • MiroTalkM
                              MiroTalkM
                              MiroTalk
                              App Maintainer
                              #34
                              By the way, I opened an issue for MinIO here: https://github.com/minio/minio/issues/21694
                              It would be great if MinIO could properly show previews for .webm videos as well.
                              When I store the same recording in a rec folder in Cloudron, the video preview works correctly.
                              However, when the file is stored in MinIO storage, the preview does not work.
                              It looks like the MIME type is not detected correctly, which causes the video tag to use:
                              type="video/mp4"
                              even though the file is actually a .webm.
                              This prevents browsers from playing the video.
                              Proper support for serving .webm with Content-Type: video/webm would fix the issue.
                              • S shrey
                                My env file ->
                                # Recording
                                MiroTalkM
                                MiroTalkM
                                MiroTalk
                                App Maintainer
                                #35
                                Just out of curiosity, on DigitalOcean, the web video preview work there?
                                I'm going also to add also the correct contentType when the recording is uploaded to any S3-compatible storage to avoid MIME-type issues.
                                S 1 Reply Last reply
                                • MiroTalkM MiroTalk
                                  S
                                  S
                                  shrey
                                  @MiroTalk said in MiroTalk SFU: Recording not possible?:
                                  No idea. I'm yet to figure out why uploading to S3 (DigitalOcean Spaces) is not working for me.
                                  • S shrey
                                    MiroTalkM
                                    MiroTalkM
                                    MiroTalk
                                    App Maintainer
                                    #37
                                    I don’t have a DigitalOcean Space to test, but in case you want to try, you can add AWS_REGION to your environment config like this:
                                    RECORDING_UPLOAD_TO_S3=true                       # Enable uploading recordings to S3-compatible storage
                                    AWS_S3_ENABLED=true                               # Enable S3 storage integration
                                    AWS_S3_ENDPOINT=https://YOUR-REGION.digitaloceanspaces.com  # DO Spaces endpoint (replace YOUR-REGION)
                                    AWS_S3_BUCKET=YOUR-BUCKET                         # Target bucket name
                                    AWS_ACCESS_KEY_ID=YOUR-DO-ACCESS-KEY              # Your DO Spaces access key
                                    AWS_SECRET_ACCESS_KEY=YOUR-DO-SECRET-KEY          # Your DO Spaces secret key
                                    AWS_REGION=YOUR-REGION                            # DO Spaces region (required)
                                    AWS_S3_FORCE_PATH_STYLE=true                      # Required for non-AWS S3 providers
                                    ✅ Notes
                                    1. Region: Must match your Space’s region (nyc3, ams3, sgp1, etc.).
                                    2. Endpoint: Must include the full URL with https://.
                                    3. MiroTalk SFU: Make sure to use at last the v2.0.17
                                    • MiroTalkM
                                      MiroTalkM
                                      MiroTalk
                                      App Maintainer
                                      Created on the fly, I can confirm that the previous configuration works as expected.
                                        S
                                        S
                                        shrey
                                        @MiroTalk Thanks for sharing the details and the screenshot.
                                        In my case, i'm getting this error:
                                        Nov 18 08:28:31 "app": "Server",
                                        Nov 18 08:28:31 "level": "error",
                                        Nov 18 08:28:31 "message": "Rec Finalization error"
                                        Nov 18 08:28:31 "timestamp": "2025-11-18T02:58:31.414Z",
                                        env ->
                                        # Recording
                                        RECORDING_UPLOAD_TO_S3=true                      # Upload recording to AWS S3 bucket [true/false]
                                        AWS_S3_BUCKET_NAME=<bucket>                       # Name of your S3 bucket (must exist)
                                        AWS_ACCESS_KEY_ID=<key_id>                                # AWS Access Key ID (leave empty for IAM roles)
                                        AWS_SECRET_ACCESS_KEY=<key_secret>                            # AWS Secret Access Key (leave empty for IAM roles)
                                        • S shrey
                                          env ->
                                          # Recording
                                          Hello @shrey
                                          Just to make doubly so sure, please share your installed app version and confirm that you have restarted the app after the /app/data/env changes.
