  2. WordPress (Managed)
  3. Not able to login with Cloudron
Scheduled Pinned Locked Moved WordPress (Managed)
9 Posts 3 Posters 1.4k Views 3 Watching
  • filterF
    filterF
    filter
    CA Maintainer
    Hey, there appears to be a problem with the recent changes around the SSO plugins. On the wp-login page, there was no more "login with Cloudron" button. I had to reset the password to be able to log in. After the login, I saw this in the plugin section.
      Hello @filter
      This could be related to https://forum.cloudron.io/topic/14730/manual-update-openid-connect-generic-to-3.10.1-login-with-cloudron-button-gone
      Can you check if that is the case?
      • filterF
        filterF
        filter
        CA Maintainer
        wrote on last edited by filter
        Seems related, but I didn't update manually.
        • J
          @filter in the Filemanager, can you open wp-content/plugins/cloudron-sso/cloudron-sso.php. It should have something like this:
           * Requires Plugins:  daggerhart-openid-connect-generic
          filterF 1 Reply Last reply
            filterF
            filterF
            filter
            CA Maintainer
            @joseph Yes, it's there.
            • J
              @filter do you use managed wordpress or developer edition? Is your wordpress in the latest version? just checking if we are debugging the correct app. have you tried to restart the app already?
                filterF
                filterF
                filter
                CA Maintainer
                @joseph I use WordPress (Managed), and I have auto-updates enabled. It's running the latest version. It was restarted a couple of times. I don't think this is specific to my setup; therefore, I have reported it.
                J 1 Reply Last reply
                • filterF filter
                  @filter thanks . So far, we cannot reproduce it. Can you please reach out at support@cloudron.io and I can take a look?
                  • filterF
                    filterF
                    filter
                    CA Maintainer
                    It was resolved by activating the OpenID plugin. I am not sure how it was deactivated in the first place.
