  2. Community Apps
  3. AgentZero
AgentZero
Scheduled Pinned Locked Moved Community Apps
7 Posts 2 Posters 724 Views 2 Watching
  • timconsidineT Online
    Community App v1.0.1 running latest upstream update 0.9.8.2 reporting an error.
    Fixing ....
    EDIT : fixed in community app 1.0.4
      Fixing node install path ....
      EDIT : fixed in community app 1.0.6
      • firmansiF Offline
        firmansiF Offline
        firmansi
        How to update if there's a new update from agentzero?
        • firmansiF firmansi
          @firmansi for my app I need to build new image, announce it here, then your Cloudron should pick it up available but often quicker to press Check Update in the app dashboard.
          On a train now, will see if anything recent, if not just go to app dashboard, Updates, Check Updates.
          • firmansiF Offline
            firmansiF Offline
            firmansi
            I havent tried it yet, is everything working well on your end?
              @firmansi yes, it’s in “in production” for me.
              Have not used everything because there’s so much that can be done. Currently for me it is :
              • one of my Telegram bot handlers, providing some basic tasks
              • handing invoice downloading from a couple of suppliers who require login and fetch
                Planning to extend its functionality.
              Only “issue” is that Searx is too slow for it so I use Brave API for search - cost is pennies.
                Upgraded to support upstream 1.20 ... and they drop a version 2.0 !
                In process of packaging 2.0
                I would treat 2.0 as a fresh install, not an upgrade to a previous installtion running 1.20 or earlier.
