  3. Reset Cloudron installation
4 Posts 3 Posters 4.2k Views 3 Watching
  • D
    D
    d.vasarelli
    Hello,
    I'm new of cloudron and I'm trying to setup a developer instance on virtualbox Ubuntu 14.04 server.
    In the setup page I inserted a wrong domain and now my installation is unuseful. I would like to fully reset that installation without re-installing all. Is it possibile?
    I tryed modifing the config file under /home/yellowtent inserting another domain but with no success.
    Thanks in advance.
    fbartelsF 1 Reply Last reply
      In such a case, the information at https://cloudron.io/documentation/domains/#changing-the-dashboard-domain should apply as well. So after changing the config file, the box process has to be restarted mostly.
      • D d.vasarelli
        Hello,
        Thanks in advance.
        fbartelsF
        fbartelsF
        fbartels
        @d-vasarelli said in Reset Cloudron installation:
        maybe it's better to redo the setup with a more up to date Ubuntu, as 14.04 will relatively soon run out of maintenance updates (and I don't know if Cloudron will actually run on it).
        Afaik Cloudron does not support 18.04, but 16.04 will give you some breathing time.
          Well spotted @fbartels in fact 14.04 is not even supported by Cloudron at all, so it likely won't work anyways.
