  2. Collabora Online (CODE)
  3. Collabora NextCloud issue
Scheduled Pinned Locked Moved Collabora Online (CODE)
collabora
7 Posts 4 Posters 4.3k Views 4 Watching
  • iamthefijI
    iamthefijI
    iamthefij
    Ok, so I've been racking my brain on this one for a while and can't figure it out.
    I've got NextCloud installed at cloud.mydomain.com, and Collabora installed at docs.mydomain.com. I've updated Collabora to allow framing by https://cloud.mydomain.com as well as updated the host name in the app itself. I've also installed the Collabora app in NextCloud as well as told it to look at https://docs.mydomain.com.
    This had been working for a while. Today I noticed it just kept spinning when trying to view a doc and see in the JavaScript console the following perplexing line:
    Loading denied by X-Frame-Options: https://md.mydomain.com/ does not permit framing by https://cloud.mydomain.com/apps/files/?dir=/path/to/doc
    What?! I do have an app (CodiMD) hosted at md.mydomain.com, however, that is something completely irrelevant. Just in case, I updated it to allow framing in https://cloud.iamthefij.com, but that doesn't seem to have helped either.
    From there I started debugging. I grepped the /app directories for md.mydomain.com in both my NextCloud and Collabora containers, but found nothing. I tried renaming md.mydomain.com to md2.mydomain.com, but I got the exact same error:
    On the other hand, when I rename docs.mydomain.com to docs2.mydomain.com, I get a NextCloud error that it can't connect to Collabora!
    So it seems like NextCloud is connecting to Collabora, but for some reason it's then trying to load a different host...
    murgeroM 1 Reply Last reply
    • iamthefijI iamthefij
      murgeroM
      murgeroM
      murgero
      @iamthefij Can you try resetting collabora? if you leave the default settings it only allows connections from your domain anyway
      https://urgero.org
        I cannot think of anything causing nextcloud to iframe some random other domain. As @murgero said reinstalling collabora on the same domain should fix this, as the defaults should be ok already.
        • iamthefijI
          iamthefijI
          iamthefij
          Tried that, but it did not fix it. For some reason it still shows the same thing.
          FYI, the default is insecure. [a-zA-Z0-9_\-.]*example.com would actually allow someone to use a malicious domain like fake-example.com and use the instance as it would match that regex. It should really be example.com|[a-zA-Z0-9_\-]+.example.com. That way it's checking for root domain or any subdomain with a dot before the domain.
          • iamthefijI
            iamthefijI
            iamthefij
            Just tried in Safari and got much more detailed information:
            [Error] Invalid 'X-Frame-Options' header encountered when loading 'https://cloud.example.com/apps/richdocuments/index?fileId=11418&requesttoken=blah': 'ALLOW-FROM https://md.example.com' is not a recognized directive. The header will be ignored.
            [Error] Invalid 'X-Frame-Options' header encountered when loading 'https://docs.example.com/loleaflet/blah/loleaflet.html?WOPISrc=https%3A%2F%2Fcloud.example.com%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F11418_blah&title=Test.odt&lang=en&closebutton=1&revisionhistory=1': 'ALLOW-FROM https://cloud.example.com' is not a recognized directive. The header will be ignored.
            It looks like both are trying to frame each other. When I did check my settings for cloud.example.com, I saw that I had allowed cloud.example.com to be embedded in md.example.com, so I'm wondering if that's where this is coming from.
            Updated both to allow embedding from each other now.
            Oddly enough I still get errors saying framing is not allowed.
            Firefox gives me:
            Load denied by X-Frame-Options: https://docs.example.com/ does not permit framing by https://cloud.example.com/apps/files/?dir=/Documents
            Safari gives me:
            [Error] Invalid 'X-Frame-Options' header encountered when loading 'https://cloud.example.com/apps/richdocuments/index?fileId=11418&requesttoken=blah%3D%blah%blah%3D': 'ALLOW-FROM https://docs.example.com' is not a recognized directive. The header will be ignored.
            [Error] Invalid 'X-Frame-Options' header encountered when loading 'https://docs.example.com/loleaflet/blah/loleaflet.html?WOPISrc=https%3A%2F%2Fcloud.example.com%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F1141blah&title=Test.odt&lang=en&closebutton=1&revisionhistory=1': 'ALLOW-FROM https://cloud.example.com' is not a recognized directive. The header will be ignored.
            The header itself shows X-Frame-Options: ALLOW-FROM https://cloud.example.com... which looks right.
            • iamthefijI
              iamthefijI
              iamthefij
              More debugging weirdness! Looks like the Safari errors can be ignored. The iframe actually seems to be loading fine. I tested using my external link to Gitea embedded in NextCloud. It renders just fine, but the errors still shows in the log. Weird.
              Then, within the Collabora frame inside NextCloud, I was getting an error saying:
              Failed to read document from storage. Please contact your storage server (cloud.example.com) administrator.
              Turns out that was related to open a new document. It now works in Safari with older documents but new documents won't work.
              Firefox still gives me the previous error, though I just noticed there is also a different error present, so maybe the X-Frame-Options one is a red herring.
              Load denied by X-Frame-Options: https://docs.example.com/ does not permit framing by https://cloud.example.com/apps/files/.
              Content Security Policy: Ignoring “'unsafe-inline'” within script-src or style-src: nonce-source or hash-source specified
              Sorry, this is a lot of info. I'm just dumping it all as I debug for someone's future reference (probably mine).
                @iamthefij I don't know if this is related, but we have an open task to move away from X-Frame-Options which seems to be deprecated - https://git.cloudron.io/cloudron/box/issues/596
