  2. OnlyOffice
  3. Question about adding fonts and custom samples for OnlyOffice ?
Scheduled Pinned Locked Moved Solved OnlyOffice
onlyoffice
12 Posts 7 Posters 6.3k Views 8 Watching
    A Former User
    Adding more fonts
    Based on this documentation they suggesting to add fonts in /usr/share/fonts/.
    Custom Templates/Sample
    Based on this issue customizing the default font is only a matter of declaring it in these samples but I can't find this public/samples directory.
    My question for Cloudron are
    1. Someone knows where is public/samples dir ?
    2. How to make my new fonts and samples persistent ?
    3. Does these modifications be included in the backup since it is not under /app ?
      I was not aware of that feature actually and thus the app package does not support this yet.
      Since apps on Cloudron run on a read-only filesystem, we have to symlink those folders into /app/data/ somewhere, that way they are also part of the backup.
      I created an issue in the app package repo at https://git.cloudron.io/cloudron/onlyoffice-app/issues/1 so we don't forget about it
        andreasduerenA
        andreasduerenA
        andreasdueren
        @nebulon Stumbled across this while trying to find out how to add custom fonts. I would appreciate this option as well since standard fonts like Helvetica aren't included plus I would like to import a company-specific font that aligns with their CI
        • darkbenD
          darkbenD
          darkben
          @nebulon +1 to add custom fonts in Onlyoffice. Do you think it will be possible in a next release of the pakage ?
          Thanks !
            The latest app package now supports adding custom fonts. See https://docs.cloudron.io/apps/onlyoffice/#custom-fonts for details.
            andreasduerenA chetbakerC osoboO 3 Replies Last reply
              andreasduerenA
              andreasduerenA
              andreasdueren
              @nebulon Awesome!
                chetbakerC
                chetbakerC
                chetbaker
                @nebulon I followed these instructions but the fonts are not shown in the web-app. I'm trying to add up the iA Writer fonts (all TTF), but restarting the app and the browser doesn't show any of the new fonts in the app.
                Any hint of what else should I do?
                micmcM 1 Reply Last reply
                • chetbakerC chetbaker
                  micmcM
                  micmcM
                  micmc
                  wrote on last edited by micmc
                  @chetbaker said in Question about adding fonts and custom samples for OnlyOffice ?:
                  Hello, you need not only to restart your brower but before doing so, you must clear the cache of it. One way to find out is trying the app in another browser, so if it works then that means the other one cache is not fully cleared. If it does not work in both, then the issue is elsewhere. 🙂
                  (coming soon...)
                  chetbakerC 1 Reply Last reply
                  • micmcM micmc
                    chetbakerC
                    chetbakerC
                    chetbaker
                    @micmc hey thanks! Yeah, I tried in another browser and no new fonts appears 😞
                      osoboO
                      osoboO
                      osobo
                      @nebulon said in Question about adding fonts and custom samples for OnlyOffice ?:
                      Hello @nebulon . Could you please check this feature again ? It seems adding fonts is not working anymore 😞
                      I've Nextcloud and OnlyOffice apps running on the same Cloudron. I'm in need to use a few custom ttf fonts to allow users to write in their local language (ie Lao fonts like these : Saysettha).
                      Despite following the process mentioned custom fonts won't show up in the menu...
                      Thanks for your support 🙏
                        I can reproduce an error with fonts at least. The app does pick up the font correctly but while trying to open the font selection dropdown it crashes if a custom font was added. The browser console shows:
                        Uncaught RangeError: attempting to construct out-of-bounds Uint8ClampedArray on ArrayBuffer
                        Not yet sure what the bug is and what needs fixing.
                        • nebulonN nebulon has marked this topic as unsolved on
                          This took a bit but the latest package version has this fixed.
