  2. Mastodon
  3. Mastodon Terminal not starting
Scheduled Pinned Locked Moved Solved Mastodon
mastodon
16 Posts 3 Posters 6.0k Views 3 Watching
  • S Offline
    S Offline
    smilebasti
    Hi, i just installed Mastodon successfully. After i created an user on the running server i tried to add the user the admin functions through the Terminal.
    The Terminal says: 'Connecting...' and 'If you resize the Window press cntrl+D....'.
    After that the screen switches to full black terminal. I have also tried recovery mode but nothing different. I also had a look in the logs but i found nothing..
    Thanks ahead for your help 🙂
      @smilebasti Usually, it will keep saying 'Connecting...' only when the app is not running. Maybe the app was just starting up? Does it say 'Running' in the apps view?
      S 1 Reply Last reply
        S Offline
        S Offline
        smilebasti
        @girish Hi thanks for the fast reply.
        Yes the App in running mode.
        It is saying 'connecting...' only for a second or two with the screen size and then is all going black (terminal)
          @smilebasti Do you see this with all apps or just mastodon?
          • S Offline
            S Offline
            smilebasti
            @girish This is also with Nextcloud (all other)
              @smilebasti Could be one of two reasons:
              1. docker is not working for whatever reason. Can you check if you can do something like docker exec -ti mysql /bin/bash on the server ? Does it give you a shell? If not, this is a docker issue which we can debug further based on the error message.
              2. Maybe some browser issue. But this seems a bit unlikely. Can you try another browser just in case some extension is causing some problem?
              • S Offline
                S Offline
                smilebasti
                @girish Ok the 2. thing is also not working.
                1. your command worked fine.
                  Can you tail -f /home/yellowtent/platformdata/logs/box.log and see if there is some crash/error when you open the terminal view? Any errors in the browser console?
                  • S Offline
                    S Offline
                    smilebasti
                    Thats the Error i get when i am starting the terminal
                    <I deleted the image because it showed the domain name - girish>
                    • S Offline
                      S Offline
                      smilebasti
                      This is the chrome console error
                      website erased
                        @smilebasti Indeed, there is a crash in cloudron in quite a strange place. That function should always be defined. Can you send us a mail to support@cloudron.io after enabling ssh access (Support -> enable remote support)?
                          OK, we found that the issue was related to having a reverse proxy in front of Cloudron. This reverse proxy was not configured properly to forward web sockets.
                          For nginx, we need something like this:
                          map $http_upgrade $connection_upgrade {
                              default upgrade;
                              '' close;
                          server {
                              proxy_set_header Upgrade $http_upgrade;
                              proxy_set_header Connection $connection_upgrade;
                          For apache, we need something like this:
                            RewriteEngine on
                            RewriteCond ${HTTP:Upgrade} websocket [NC]
                            RewriteCond ${HTTP:Connection} upgrade [NC]
                            RewriteRule .* "wss:/192.168.20.12/$1" [P,L]
                          For the moment, one can just use SSH to open a web terminal like this:
                          docker ps -f label=fqdn=app.domain.com
                          docker exec -ti <containerid_from_above> /bin/bash
                          A 1 Reply Last reply
                                default upgrade;
                                '' close;
                            server {
                              RewriteEngine on
                            A Offline
                            A Offline
                            alwynispat
                            @girish I have similar issues, I’m using the nginx proxy manager. Everything works but the app terminal. Already tried your config for ngix but didn’t work.
                            Find me at Mastodon
                            • A alwynispat
                              @alwynispat Could be because websocket is not getting forwarded properly via the proxy manager. Does it work without the proxy manager?
                                A Offline
                                A Offline
                                alwynispat
                                @girish found the culprit, NPM was not forwarding the web socket properly. Fixed that and the terminal works now.
                                Find me at Mastodon
                                • A alwynispat
                                  @alwynispat do you mean nginx? How is NPM involved here?
                                  edit: oh, maybe you mean your nginx proxy manager?
