  2. Matrix (Synapse/Element)
  3. Element custom background
Scheduled Pinned Locked Moved Solved Matrix (Synapse/Element)
10 Posts 5 Posters 6.5k Views 6 Watching
  • ClipperC Offline
    ClipperC Offline
    Clipper
    I'm running a Cloudron on AWS E2 (from marketplace) with a Matrix App and an Element App.
    I'd like to make use of the Element custom branding such as WelcomeBackgroundUrl as per
    Configure auth footer links through Riot config #9297
    But apparently the entire filesystem except /app/data is read-only. Where could I store a background image which would be served (accessible) and not deleted upon package updates ?
    Thanks
      On Cloudron apps run in a read-only filesystem for the most part. Potential customization files will reside in /app/data
      In your case the config.json can be edited as mentioned in https://docs.cloudron.io/apps/element/
      ClipperC 1 Reply Last reply
        ClipperC Offline
        ClipperC Offline
        Clipper
        @nebulon Yes, I know that, and I did 🙂 However what URL could I use for a setting like WelcomeBackgroundUrl that could actually be served by the web server ?
        currently the background image is url("themes/element/img/backgrounds/lake.jpg"), relative to /app/code/. I can upload another background image in /app/data but it will be unreachable. Would it be possible to symlink a new /app/code/themes/custom/ directory to /app/data/themes/ ?
        So that we could set e.g. "welcomeBackgroundUrl": "themes/custom/mynicebg.jpg"
        and upload the file into /app/data/themes/mynicebg.jpg
        Hope it's more clear like that.
        ruihildtR murgeroM 2 Replies Last reply
        • ClipperC Clipper
          ruihildtR Offline
          ruihildtR Offline
          ruihildt
          @Clipper If it's relative to /app/code, you could try doing ../data/folder/image.jpg.
          • ClipperC Clipper
            murgeroM Offline
            murgeroM Offline
            murgero
            @Clipper You can use an external image, in the following config example, I used minio on my server to change the backround and logo images, I recommend surfer though for the easier upload and sharing of the images.
            (I used the cloudron logo as an example without permissions, copyrights to the cloudron team.)
            (Background from google images)
            config.json:
              "disable_custom_urls": true,
              "disable_guests": true,
              "disable_login_language_selector": false,
              "disable_3pid_login": true,
              "brand": "Riot",
              "branding": {
                "welcomeBackgroundUrl":"<external_URL>",
                "authHeaderLogoUrl":"<external_URL>"
              "integrations_ui_url": "https://scalar.vector.im/",
              "integrations_rest_url": "https://scalar.vector.im/api",
            https://urgero.org
            • ruihildtR ruihildt
              ClipperC Offline
              ClipperC Offline
              Clipper
              @ruihildt said in Element custom background:
              Yeah... nice try but that would be pretty silly if it worked, as you could access ../data/config.json or even ../../etc/shadow straight from any browser 😉 . There is a good reason why web roots exist.
              I'll go for the external URL as @murgero proposed. However I think it's a horrible idea to rely on external sources. I still like my idea of a /app/code/themes/custom -> /app/data/themes symlink 🙂
              This is by the way exactly how config.json is pulled up:
              /app/code/config.json -> /app/data/config.json
              Thanks
              murgeroM 1 Reply Last reply
              • ClipperC Clipper
                Thanks
                murgeroM Offline
                murgeroM Offline
                murgero
                wrote on last edited by murgero
                @Clipper said in Element custom background:
                Yeah - This would be a good bit to have in the next update @girish / @nebulon
                https://urgero.org
                  Makes sense, seems easy to fix. There's a new element version available now, so I will fix it up as part of that.
                    This is should be fixed now. There is a custom directory /app/data/custom in the latest package.
                      ClipperC Offline
                      ClipperC Offline
                      Clipper
                      @girish Awesome thank you it works like a charm. Marking as solved.
