  3. Nginx setting to allow wss sockets to connect
5 Posts 3 Posters 2.0k Views 2 Watching
    Having run across this at a previous robotics project doing Tele-existence, things weren't connecting well.
    General idea of the config:
    https + proxy pass + virtual host
    Nginx as a proxy causes a failure of wss:// connections to the backend server.
    Add these parameters to the proxy section :
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection “upgrade”;
    proxy_set_header Host $host;
    Voila
      Yup. FWIW, this is already enabled in Cloudron's nginx configuration for apps.
      imc67I 1 Reply Last reply
        imc67I Offline
        imc67I Offline
        imc67
        This looks like a similar issue with wss as in https://forum.cloudron.io/topic/3414/transcode-after-import-fails/23?_=1606977647141?
        • imc67I imc67
          @imc67 I don't think @robi was reporting an issue, but just giving a helpful suggestion. Many apps already use wss on Cloudron like mattermost, rocket.chat (and Cloudron dashboard).
            imc67I Offline
            imc67I Offline
            imc67
            @girish ok, sorry, I think I was reading to fast and recognized wss: is an 503 error in PeerTube.
            Does the PeerTube app also has these settings?
