  3. hostPath does not exist
volumes
5 Posts 3 Posters 2.5k Views 4 Watching
  • D Offline
    D Offline
    drpaneas
    As soon as I setup cloudron I get this notifcation:
    Backup configuration is unsafe 21 hours ago
    Cloudron backups are currently on the same disk as the Cloudron server instance. This is dangerous and can lead to complete data loss if the disk fails. See https://docs.cloudron.io/backups/#storage-providers for storing backups in an external location.
    So I connect an external USB hard-disk on the server to use it as a backup volume. It's mounted at /media/drpaneas/Backup and has ext4 filesystem:
    $ mount |grep /dev/sdb1
    /dev/sdb1 on /media/drpaneas/Backup type ext4 (rw,nosuid,nodev,relatime,uhelper=udisks2)
    However when I am adding this to cloudron I get an error:
    hostPath does not exist. Please create it on the server first
      Just for information, from the backup configuration warning I would have assumed you would setup backups on that disk, however you are trying to setup a volume. Backups and volumes are not really related on Cloudron.
      Still you should be able to add a volume, will check to see if I can spot the issue in code.
      nebulonN D 2 Replies Last reply
        I don't really see why that error would come up. Just for testing, can you create a subdirectory within that mountpoint, for example /media/drpaneas/Backup/test/ and then try to add that as the volume?
          D Offline
          D Offline
          drpaneas
          wrote on last edited by drpaneas
          @nebulon said in hostPath does not exist:
          From what I understand, the warning says that Cloudron and Cloudron Backups will happen on the same disk and that's not the best way to go -- thus the warning.
          So I added a new external disk on the system.
          I've tried this and it doesn't work.
          Eventually I've managed to add the volume, using /media/drpaneas.
          So:
          `/media/drpaneas` # works
          `/media/drpaneas/Backup` # fails
          `/media/drpaneas/Backup/test` #fails
          I solved the issue eventually when I added this folder Backup as the backup. Note that it asked me to change the user first:
          chown yellowtent:yellowtent /media/drpaneas/Backup/
          so in the end it's working.
          • D drpaneas
            So:
            @drpaneas Ah thanks, I think I found the bug. It seems a "permission denied" issue is being flagged incorrectly as directory does not exist. The chown you did essentially changed permissions and fixed the issue.
