  3. Uptime Monitoring
Uptime Monitoring
27 Posts 13 Posters 13.0k Views 15 Watching
    @mazarian just to provide some some other experience, I downloaded @atridad repo files, but I did not use cloudron build. I went "the long way".
    docker build -t <myrepo>/<appname>:<tag> .
    docker push <myrepo>/<appname>:<tag>
    cloudron install --image <myrepo>/<appname>:<tag>
    NB the trailing dot on 1st line
    With this the build/install was seamless
    Kuma now working brilliantly and I have deleted my UptimeRobot account.
    thanks again @atridad
    mazarian
    @timconsidine Thanks for this! I'm not sure how much of my issue had to do with my Mac environment but I was able to get it all setup using Ubuntu using your method and it worked like a charm!
    • M mazarian
      #22
      @mazarian Great
      I should have mentioned that I am a Mac user, and was doing this on a Mac Mini running Big Sur and Docker Desktop. Maybe too late to be helpful, sorry.
      • ? A Former User
        @timconsidine Perhaps I should change my instructions? @staff does the cloudron build command do some extra stuff that would be causing this?
        @atridad said in Uptime Monitoring:
        errr, I'm not qualified on that !
        I blunder about, find what works for me and tend to stick to that.
        ? 1 Reply Last reply
          A Former User
          @timconsidine lol with packaging I'm the same way tbh. Cloudron was my first time editing or making a Dockerfile
          • M mazarian
            This looks like exactly what I've been looking for for a really long time! Thanks for bringing this over to Cloudron. 😃 I tried installing it via Cloudron CLI from my Mac and it's throwing an error when I run cloudron build. It's my first time installing a 3rd party app, so maybe I'm doing it totally wrong.
            I signed into my Cloudon instance in CLI, cloned the repo onto my computer, went into the directory, and typed cloudron build.
            I've made sure my Node instance is up to date (using Homebrew) and I also have Docker installed via Homebrew as well.
            Any help would greatly be appreciated!
            Building locally as git.atridad.dev/CTPR/cloudron-uptime-kuma-app:20210714-143642-23560f15f
            invalid argument "git.atridad.dev/CTPR/cloudron-uptime-kuma-app:20210714-143642-23560f15f" for "-t, --tag" flag: invalid reference format: repository name must be lowercase
            See 'docker build --help'.
            node:child_process:903
                throw err;
            Error: Command failed: docker build  -t git.atridad.dev/CTPR/cloudron-uptime-kuma-app:20210714-143642-23560f15f -f Dockerfile  /Users/michael/Downloads/cloudron-uptime-kuma-app
                at checkExecSyncError (node:child_process:826:11)
                at execSync (node:child_process:900:15)
                at buildLocal (/usr/local/lib/node_modules/cloudron/src/build-actions.js:187:5)
                at Command.build (/usr/local/lib/node_modules/cloudron/src/build-actions.js:349:9)
                at Command.listener [as _actionHandler] (/usr/local/lib/node_modules/cloudron/node_modules/commander/index.js:426:31)
                at Command._parseCommand (/usr/local/lib/node_modules/cloudron/node_modules/commander/index.js:1002:14)
                at Command._dispatchSubcommand (/usr/local/lib/node_modules/cloudron/node_modules/commander/index.js:953:18)
                at Command._parseCommand (/usr/local/lib/node_modules/cloudron/node_modules/commander/index.js:970:12)
                at Command.parse (/usr/local/lib/node_modules/cloudron/node_modules/commander/index.js:801:10)
                at Object.<anonymous> (/usr/local/lib/node_modules/cloudron/bin/cloudron:261:9) {
              status: 125,
              signal: null,
              output: [ null, null, null ],
              pid: 9877,
              stdout: null,
              stderr: null
            @mazarian said in Uptime Monitoring:
            I think this happenned because the docker repository was specified incorrectly when you did cloudron build. You can always cloudron build --set-repository again and it will ask you again for the repository name. The repo name should like girish/cloudron-uptime-kuma or something like that. The first part is your handle on docker hub (or equivalent). The second part is the repository name. In docker terminology, a repo is something that holds many images.
            mehdiM M 2 Replies Last reply
              mehdiM
              mehdiM
              mehdi
                mazarian
                @girish You are 100% right. I'm new to a lot of this. Thank you again for all of your help!
