  3. LinkAce
LinkAce
4 Posts 4 Posters 2.2k Views 4 Watching
  • M Offline
    M Offline
    mwithrow
    https://www.linkace.org/
    Bookmarking solution.
    GitHub: https://github.com/Kovah/LinkAce
    ruihildtR 1 Reply Last reply
    • M mwithrow
      ruihildtR Offline
      ruihildtR Offline
      ruihildt
      The autosave to archive.org and health tracking of links is super interesting feature, and the API makes it even more attractive to integrate to any workflow.
      • necrevistonnezrN Offline
        Looks really nice.
        LinkAce ships with pre-configured Docker configurations and a built-in web installer to make things as easy as possible. Installation via Docker is the recommended way.
        Features as per https://www.linkace.org/features/:
        Automated Backups and Monitoring
        • After you saved a link, it will automatically saved by the Internet Archive. A reliable backup without maintenance. LinkAce will also monitor your links and notify you, if something's wrong.
        Tags, Lists, organize your Links
        • Add tags to your links for categorization. Organize links in lists for broader or very specific topics. This will help you find your links in the future.
        Darkmode
        • Whether you want it all the time or based on your operating system: LinkAce handles light and dark mode for you.
        LinkAce Dashboard Preview
        • LinkAce Privacy Settings Preview
        • Guest Mode & Privacy
        • You can allow guests to view your link collection. However, access can be controlled for each link, tag and list separately.
        LinkAce API
        • With a simple API key, other tools can access or edit all data within LinkAce. Connect the application with your favorite tools, integrate it into your workflow.
        • Advanced Search
        • With the help of many filters and search options, it's easier to find links when you need them. Filter by tags, lists or private links, for example.
        The Bookmarklet
        • Instead of bulky browser extensions, LinkAce provides an easy to use Bookmarklet. Save any website with a simple click. It also supports using the current text selection as a description for the link.
        More Features
        • Titles, descriptions and thumbnails are generated automatically once you saved a link in LinkAce.
        • Add unlimited notes to links to add thoughts, details, to dos or whatever you don't want to put into the link description.
        • Both private and public links are accessible via RSS feeds.
        • You can import existing bookmarks from your browser based on a standard HTML file. Or export all links saved in LinkAce to this standard format to be consumed by browsers or other applications.
        • The app can be backed up to Amazon AWS, including both the application files and the database.
        • Links, tags, lists or notes are not permanently deleted. A trash holds all "deleted" entries so nothing gets lost accidentally. You can restore all entries from the trash.
        • To make sharing as easy as possible, LinkAce prepares share links for a lot of different apps: email, Twitter, Whatsapp, Reddit,...
        • Changes made to links are logged in the database so you know when you changed a title or the system marked a link as broken.
        • A lot of configuration options ensure that LinkAce fits your needs: timezone, time and date formats, defaults for link creation, and many more.
        • ? Offline
          ? Offline
          A Former User
          Miniflux now integrates with LinkAce.
