  3. Problem updating from Cloudron 6.1.2 to 6.2.4
update
6 Posts 2 Posters 2.9k Views 2 Watching
  • madrushM
    madrushM
    madrush
    This update keeps timing out on me, with error messages such as the following:
      "taskId": "6395",
      "errorMessage": "update exited with code 1 signal null",
      "timedOut": false
    2021-03-13T06:30:16.608Z box:updater Update failed with error { stack:
       'BoxError: update exited with code 1 signal null\n    at ChildProcess.<anonymous> (/home/yellowtent/box/src/shell.js:66:17)\n    at ChildProcess.emit (events.js:198:13)\n    at ChildProcess.EventEmitter.emit (domain.js:448:20)\n    at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)',
      reason: 'Spawn Error',
      details: {},
      message: 'update exited with code 1 signal null',
      code: 1,
      signal: null }
    girishG 2 Replies Last reply
    • madrushM madrush
        "taskId": "6395",
        "timedOut": false
        details: {},
        code: 1,
        signal: null }
      @madrush Can you look into /home/yellowtent/platformdata/logs/tasks/6395.log ?
      madrushM 1 Reply Last reply
      • madrushM madrush
          "taskId": "6395",
          "timedOut": false
          details: {},
          code: 1,
          signal: null }
        @madrush Are you on ubuntu 16 by any chance? If so, I just debugged a server with a similar back trace. If you do journalctl -u cloudron-updater, do you see "no entries" ? It seems there is some systemd issue. In my case, a reboot of the server fixed it.
          madrushM
          madrushM
          madrush
          @girish: In the log, after all the backups are completed, I see the following entries in the log:
          2021-03-16T07:40:49.065Z box:tasks 6395: {"percent":75.31538461538463,"message":"box: Copied 10177 files with error: null"}
          2021-03-16T07:40:49.069Z box:backups Rotated box backup successfully as id 2021-03-16-070020-445/box_2021-03-16-073619-390_v6.1.2
          2021-03-16T07:40:49.069Z box:updater updating box https://prod-cloudron-releases.s3.amazonaws.com/box-3ee3786936-4dffce0b71-6.2.4.tar.gz
          2021-03-16T07:40:49.069Z box:tasks 6395: {"percent":70,"message":"Installing update"}
          2021-03-16T07:40:49.069Z box:shell update spawn: /usr/bin/sudo -S /home/yellowtent/box/src/scripts/update.sh /tmp/box-1465958658
          2021-03-16T07:40:49.081Z box:shell update (stdout): Updating Cloudron with /tmp/box-1465958658
          2021-03-16T07:40:49.082Z box:shell update (stdout): => reset service cloudron-updater status (of previous update)
          2021-03-16T07:40:49.085Z box:shell update (stdout): => Run installer.sh as cloudron-updater.
          2021-03-16T07:40:49.089Z box:shell update (stdout): => starting service (ubuntu 16.04) cloudron-updater. see logs using journalctl -u cloudron-updater
          2021-03-16T07:40:49.094Z box:shell update (stdout): Failed to start transient service unit: Unit cloudron-updater.service already exists.
          2021-03-16T07:40:49.094Z box:shell update (stdout): Failed to install cloudron. See log for details
          2021-03-16T07:40:49.094Z box:shell update code: 1, signal: null
          2021-03-16T07:40:49.097Z box:taskworker Task took 2447.75 seconds
          2021-03-16T07:40:49.097Z box:tasks setCompleted - 6395: {"result":null,"error":{"stack":"BoxError: update exited with code 1 signal null\n    at ChildProcess.<anonymous> (/home/yellowtent/box/src/shell.js:66:17)\n    at ChildProcess.emit (events.js:198:13)\n    at ChildProcess.EventEmitter.emit (domain.js:448:20)\n    at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)","name":"BoxError","reason":"Spawn Error","details":{},"message":"update exited with code 1 signal null","code":1,"signal":null}}
          2021-03-16T07:40:49.097Z box:tasks 6395: {"percent":100,"result":null,"error":{"stack":"BoxError: update exited with code 1 signal null\n    at ChildProcess.<anonymous> (/home/yellowtent/box/src/shell.js:66:17)\n    at ChildProcess.emit (events.js:198:13)\n    at ChildProcess.EventEmitter.emit (domain.js:448:20)\n    at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)","name":"BoxError","reason":"Spawn Error","details":{},"message":"update exited with code 1 signal null","code":1,"signal":null}}
          Also, doing journalctl -u cloudron-updater does return -- No entries --.
          • madrushM madrush
            @madrush Right, I guess this is Ubuntu 16 as well. There seems to some bug in systemd which makes the updater task not run. To fix:
            • First, reboot the server.
            • sudo purge-old-kernels <- this seems to take a bit at times since it accumulates a lot of stable kernels. It also keeps asking to keep config (you can just choose the default).
            • sudo apt autoremove
            • sudo apt autoclean
            • Then, try to update
              madrushM
              madrushM
              madrush
              @girish That did the trick. Thanks!
