  2. AdGuard Home
  3. HTTP 400 code "invalid mount config for type "bind": bind source path does not exist" when installing AdGuard Home
Scheduled Pinned Locked Moved AdGuard Home
16 Posts 4 Posters 4.5k Views 4 Watching
  • d19dotcaD
    d19dotcaD
    d19dotca
    I tried installing AdGuard Home app for the first time, and unfortunately it failed immediately with the following error:
    (HTTP code 400) unexpected - invalid mount config for type "bind": bind source path does not exist: /home/yellowtent/boxdata/certs/d19.ca.host.cert
    Any idea why this might happen? Am I supposed to be mounting a volume to it or something? My boxdata folder is symlinked to an external disk, is that possibly a cause of this issue? I also noticed a recent update to it 12 days ago with a release note that seems like it coud be possibly related... fix bug where tls cert and key path were not set in the config file(https://forum.cloudron.io/post/28389)
    Dustin Dauncey
    www.d19.ca
    • S
      S
      sysadmin
      I was going to test on the demo to reproduce, but this app is disabled in the demo. Any updates on this?
        Looks like I missed this post somehow. @sysadmin are you hitting the same issue?
        The app is disabled in the demo for security reasons.
        S 1 Reply Last reply
          S
          S
          sysadmin
          @girish No, I just wanted to try and help or see if this was still happening on behalf of OP. Sorry I do not have an active pro subscription to test further. I am not sure if this issue is still occurring.
          Given the abuse potential, I would call it wise to disable this one on the demo 🙂 just wanted to check
          • d19dotcaD
            d19dotcaD
            d19dotca
            Thanks for bumping this @sysadmin 🙂
            I haven't tried it since I posted it since it was a non-starter. I'll try it again soon and see if I still run into the same issue in case there was an updated version in the meantime.
            Dustin Dauncey
            www.d19.ca
            • E
              E
              enesaydogan
              same error while trying to install adguard.
              (HTTP code 400) unexpected - invalid mount config for type "bind": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert
              • E enesaydogan
                @enesaydogan that gives me a good hint. Are you trying to install this in the bare domain? Do you get the same error if you install it in a subdomain?
                d19dotcaD E 2 Replies Last reply
                  d19dotcaD
                  d19dotcaD
                  d19dotca
                  @girish Speaking for myself, I tried it on a subdomain (I think I tried dns.<domain>), and that's the error I encountered and then reported it here.
                  Dustin Dauncey
                  www.d19.ca
                    E
                    E
                    enesaydogan
                    @girish was trying to install on subdomain
                    exp: dns.domain.com
                    • E enesaydogan
                      exp: dns.domain.com
                      @enesaydogan ok, I just realized from the error message that it is looking for .host.cert file. This means that it is using the "fallback" certificate i.e it couldn't get a proper certificate for the app and had to resort to using the fallback certificate. Can you see the app installation logs to see why it failed to get the cert? Can you also check if the file in the error message exists on the server?
                      E d19dotcaD 3 Replies Last reply
                        E
                        E
                        enesaydogan
                        wrote on last edited by enesaydogan
                        @girish this is the log from first install to error.
                        May 11 21:59:00 box:shell removeCollectdProfile (stdout): Removing collectd stats of 7ab25c70-b5ee-46ca-bb0d-caec99b084c0
                        May 11 21:59:00 box:shell removeLogrotateConfig spawn: /usr/bin/sudo -S /home/yellowtent/box/src/scripts/configurelogrotate.sh remove 7ab25c70-b5ee-46ca-bb0d-caec99b084c0
                        May 11 21:59:00 box:apptask dns.sinanerholding.com.tr updating app with values: {"containerId":null}
                        May 11 21:59:00 box:services dns.sinanerholding.com.tr teardownAddons: Tearing down ["localstorage","tls"]
                        May 11 21:59:00 box:services dns.sinanerholding.com.tr Tearing down addon localstorage with options {}
                        May 11 21:59:00 box:services dns.sinanerholding.com.tr teardownLocalStorage
                        May 11 21:59:00 box:services dns.sinanerholding.com.tr Tearing down addon tls with options {}
                        May 11 21:59:00 box:apptask dns.sinanerholding.com.tr updating app with values: {"containerIp":"172.18.20.60"}
                        May 11 21:59:00 box:tasks 6191: {"percent":20,"message":"Downloading icon"}
                        May 11 21:59:00 box:apptask dns.sinanerholding.com.tr Downloading icon of com.adguard.home.cloudronapp@1.3.2
                        May 11 21:59:00 box:tasks 6191: {"percent":30,"message":"Registering subdomains"}
                        May 11 21:59:00 box:domains registerLocations: Will register [{"subdomain":"dns","domain":"sinanerholding.com.tr"}] with options {"overwriteDns":true}
                        May 11 21:59:01 box:tasks 6191: {"message":"Registering location: dns.sinanerholding.com.tr"}
                        May 11 21:59:01 box:domains Unable to read fallback certificates of sinanerholding.com.tr from disk
                        May 11 21:59:01 box:dns/digitalocean getInternal: getting dns records of sinanerholding.com.tr with dns and type A
                        May 11 21:59:01 box:dns/digitalocean getInternal: null [{"id":149428444,"type":"A","name":"dns","data":"165.22.30.61","priority":null,"port":null,"ttl":30,"weight":null,"flags":null,"tag":null}]
                        May 11 21:59:01 box:dns/digitalocean get: ["165.22.30.61"]
                        May 11 21:59:01 box:domains upsertDNSRecord: dns on sinanerholding.com.tr type A values [ '138.68.70.212' ]
                        May 11 21:59:01 box:dns/digitalocean upsert: dns for zone sinanerholding.com.tr of type A with values ["138.68.70.212"]
                        May 11 21:59:02 box:dns/digitalocean getInternal: null [{"id":149428444,"type":"A","name":"dns","data":"165.22.30.61","priority":null,"port":null,"ttl":30,"weight":null,"flags":null,"tag":null}]
                        May 11 21:59:07 box:dns/digitalocean upsert: completed with recordIds:[149428444]
                        May 11 21:59:07 box:tasks 6191: {"percent":40,"message":"Downloading image"}
                        May 11 21:59:07 box:docker downloadImage cloudron/com.adguard.home.cloudronapp:20210506-211453-697063d5e
                        May 11 21:59:07 box:docker Downloading image cloudron/com.adguard.home.cloudronapp:20210506-211453-697063d5e. attempt: 1
                        May 11 21:59:07 box:docker pullImage: will pull cloudron/com.adguard.home.cloudronapp:20210506-211453-697063d5e. auth: no
                        May 11 21:59:08 box:docker pullImage: {"status":"Pulling from cloudron/com.adguard.home.cloudronapp","id":"20210506-211453-697063d5e"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"83ee3a23efb7"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"db98fc6f11f0"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"f611acd52c6c"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"dcded93e417d"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"87b63eef5647"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"006937d76cc6"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"8dab9e9d2594"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"2d86b342da5c"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"3bced370dd4c"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"038d1280ed6d"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"71963bcc2a55"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"62a3a16fcb86"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"f6927aea9342"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Already exists","progressDetail":{},"id":"88a76cf7025c"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Pulling fs layer","progressDetail":{},"id":"65425573f897"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Pulling fs layer","progressDetail":{},"id":"8b5bc2316013"}
                        May 11 21:59:08 box:docker pullImage: {"status":"Pulling fs layer","progressDetail":{},"id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Downloading","progressDetail":{"current":141,"total":141},"progress":"[==================================================>] 141B/141B","id":"65425573f897"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Verifying Checksum","progressDetail":{},"id":"65425573f897"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Download complete","progressDetail":{},"id":"65425573f897"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":141,"total":141},"progress":"[==================================================>] 141B/141B","id":"65425573f897"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Downloading","progressDetail":{"current":110158,"total":10782644},"progress":"[> ] 110.2kB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Downloading","progressDetail":{"current":609,"total":1714},"progress":"[=================> ] 609B/1.714kB","id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Downloading","progressDetail":{"current":1714,"total":1714},"progress":"[==================================================>] 1.714kB/1.714kB","id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Verifying Checksum","progressDetail":{},"id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Download complete","progressDetail":{},"id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Downloading","progressDetail":{"current":9370038,"total":10782644},"progress":"[===========================================> ] 9.37MB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Verifying Checksum","progressDetail":{},"id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Download complete","progressDetail":{},"id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Pull complete","progressDetail":{},"id":"65425573f897"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":131072,"total":10782644},"progress":"[> ] 131.1kB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":1179648,"total":10782644},"progress":"[=====> ] 1.18MB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":4980736,"total":10782644},"progress":"[=======================> ] 4.981MB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":9568256,"total":10782644},"progress":"[============================================> ] 9.568MB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":10782644,"total":10782644},"progress":"[==================================================>] 10.78MB/10.78MB","id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Pull complete","progressDetail":{},"id":"8b5bc2316013"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Extracting","progressDetail":{"current":1714,"total":1714},"progress":"[==================================================>] 1.714kB/1.714kB","id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Pull complete","progressDetail":{},"id":"a1d57fe8291d"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Digest: sha256:e98ed7deb4da7a38e4f31345a3223185ea1ec8a6f66075fd407d822d2e6b24e5"}
                        May 11 21:59:09 box:docker pullImage: {"status":"Status: Downloaded newer image for cloudron/com.adguard.home.cloudronapp:20210506-211453-697063d5e"}
                        May 11 21:59:09 box:docker downloaded image cloudron/com.adguard.home.cloudronapp:20210506-211453-697063d5e
                        May 11 21:59:09 box:tasks 6191: {"percent":50,"message":"Creating app data directory"}
                        May 11 21:59:09 box:tasks 6191: {"percent":60,"message":"Setting up addons"}
                        May 11 21:59:09 box:services dns.sinanerholding.com.tr setupAddons: Setting up ["localstorage","tls"]
                        May 11 21:59:09 box:services dns.sinanerholding.com.tr Setting up addon localstorage with options {}
                        May 11 21:59:09 box:services dns.sinanerholding.com.tr setupLocalStorage
                        May 11 21:59:09 box:shell createVolume spawn: /usr/bin/sudo -S /home/yellowtent/box/src/scripts/mkdirvolume.sh /home/yellowtent/appsdata/7ab25c70-b5ee-46ca-bb0d-caec99b084c0/data
                        May 11 21:59:09 box:services dns.sinanerholding.com.tr Setting up addon tls with options {}
                        May 11 21:59:09 box:tasks 6191: {"percent":70,"message":"Creating container"}
                        May 11 21:59:09 box:apptask dns.sinanerholding.com.tr creating container
                        May 11 21:59:09 box:domains Unable to read fallback certificates of sinanerholding.com.tr from disk
                        May 11 21:59:09 box:apptask dns.sinanerholding.com.tr error installing app: BoxError: (HTTP code 400) unexpected - invalid mount config for type "bind": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert
                        at /home/yellowtent/box/src/docker.js:446:44
                        at /home/yellowtent/box/node_modules/dockerode/lib/docker.js:70:23
                        at /home/yellowtent/box/node_modules/docker-modem/lib/modem.js:309:7
                        at getCause (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:331:7)
                        at Modem.buildPayload (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:300:5)
                        at IncomingMessage.<anonymous> (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:275:14)
                        at IncomingMessage.emit (events.js:327:22)
                        at endReadableNT (internal/streams/readable.js:1327:12)
                        at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                        reason: 'Docker Error',
                        details: [Object],
                        nestedError: [Error]
                        May 11 21:59:09 box:apptask dns.sinanerholding.com.tr updating app with values: {"installationState":"error","error":{"message":"(HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert ","statusCode":400,"json":{"message":"invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert"},"taskId":"6191","installationState":"pending_install"}}
                        May 11 21:59:09 box:taskworker Task took 10.079 seconds
                        May 11 21:59:09 box:tasks setCompleted - 6191: {"result":null,"error":{"stack":"BoxError: (HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert \n at /home/yellowtent/box/src/docker.js:446:44\n at /home/yellowtent/box/node_modules/dockerode/lib/docker.js:70:23\n at /home/yellowtent/box/node_modules/docker-modem/lib/modem.js:309:7\n at getCause (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:331:7)\n at Modem.buildPayload (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:300:5)\n at IncomingMessage.<anonymous> (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:275:14)\n at IncomingMessage.emit (events.js:327:22)\n at endReadableNT (internal/streams/readable.js:1327:12)\n at processTicksAndRejections (internal/process/task_queues.js:80:21)","name":"BoxError","reason":"Docker Error","details":{},"message":"(HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert ","nestedError":{"stack":"Error: (HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert \n at /home/yellowtent/box/node_modules/docker-modem/lib/modem.js:301:17\n at getCause (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:331:7)\n at Modem.buildPayload (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:300:5)\n at IncomingMessage.<anonymous> (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:275:14)\n at IncomingMessage.emit (events.js:327:22)\n at endReadableNT (internal/streams/readable.js:1327:12)\n at processTicksAndRejections (internal/process/task_queues.js:80:21)","name":"Error","message":"(HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert "}}}
                        May 11 21:59:09 box:tasks 6191: {"percent":100,"result":null,"error":{"stack":"BoxError: (HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert \n at /home/yellowtent/box/src/docker.js:446:44\n at /home/yellowtent/box/node_modules/dockerode/lib/docker.js:70:23\n at /home/yellowtent/box/node_modules/docker-modem/lib/modem.js:309:7\n at getCause (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:331:7)\n at Modem.buildPayload (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:300:5)\n at IncomingMessage.<anonymous> (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:275:14)\n at IncomingMessage.emit (events.js:327:22)\n at endReadableNT (internal/streams/readable.js:1327:12)\n at processTicksAndRejections (internal/process/task_queues.js:80:21)","name":"BoxError","reason":"Docker Error","details":{},"message":"(HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert ","nestedError":{"stack":"Error: (HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert \n at /home/yellowtent/box/node_modules/docker-modem/lib/modem.js:301:17\n at getCause (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:331:7)\n at Modem.buildPayload (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:300:5)\n at IncomingMessage.<anonymous> (/home/yellowtent/box/node_modules/docker-modem/lib/modem.js:275:14)\n at IncomingMessage.emit (events.js:327:22)\n at endReadableNT (internal/streams/readable.js:1327:12)\n at processTicksAndRejections (internal/process/task_queues.js:80:21)","name":"Error","message":"(HTTP code 400) unexpected - invalid mount config for type \"bind\": bind source path does not exist: /home/yellowtent/boxdata/certs/sinanerholding.com.tr.host.cert "}}}
                        I checked server for the file. dont have this file on the server.
                          E
                          E
                          enesaydogan
                          @girish weird thin is my old domain file exist. I was using this domain when i first installed cloudron.
                          /home/yellowtent/boxdata/certs/sinanergrup.com.host.cert
                            d19dotcaD
                            d19dotcaD
                            d19dotca
                            @girish I realized I have boxdata as a symblink to an external disk which caused issues in restoring Cloudron before until it was later fixed... is it possible that is an issue in this app package too? Boxdata is where the certs are stored, right? Wonder if that's related here then.
                            @enesaydogan - do you happen to have your boxdata on a seperate disk?
                            Dustin Dauncey
                            www.d19.ca
                            E 1 Reply Last reply
                            • d19dotcaD d19dotca
                              E
                              E
                              enesaydogan
                              @d19dotca No my vps dont have sperate disk. All instalation on single disk.
                              • E enesaydogan
                                @enesaydogan you can delete that file, if you don't use that domain anymore.
                                I can't really make out what is wrong. If you can mail us at support@cloudron.io, I can take a look as to why it's failing.
                                  E
                                  E
                                  enesaydogan
                                  @girish Thanks. Sendding now.
                                  • S saint referenced this topic on
