  2. Matomo
  3. Matomo system check report showing a warning for "LOAD DATA INFILE" with "access denied" as the root cause
Scheduled Pinned Locked Moved Solved Matomo
7 Posts 2 Posters 3.8k Views 2 Watching
  • d19dotcaD Offline
    d19dotcaD Offline
    d19dotca
    I noticed today (not sure how long it's been present for though) the Matomo system report is showing the following:
    LOAD DATA INFILE
    Using LOAD DATA INFILE will greatly speed Matomo's archiving process up. To make it available to Matomo, try updating your PHP & MySQL software and make sure your database user has the FILE privilege.
    If your Matomo server tracks high traffic websites (eg. > 100,000 pages per month), we recommend trying to fix this problem.
    Error: LOAD DATA INFILE failed... Error was:
    Try #1: LOAD DATA INFILE : SQLSTATE[28000]: Invalid authorization specification: 1045 Access denied for user '<randomUserID>'@'%' (using password: YES)[28000],
    Try #2: LOAD DATA LOCAL INFILE : SQLSTATE[42000]: Syntax error or access violation: 3948 Loading local data is disabled; this must be enabled on both the client and server sides[42000]
    Troubleshooting: FAQ on matomo.org
    Does anyone else see this too in their Matomo installs?
    Now I don't have any websites serving up more than 100,000 pages a month so this isn't critical by any means, but I suppose it wouldn't hurt to follow its guidance anyways? It seems like it's enabled anyways and was more of a access issue, but how do I fix this?
    Dustin Dauncey
    www.d19.ca
    • d19dotcaD d19dotca
      LOAD DATA INFILE
      @d19dotca Same as https://forum.cloudron.io/topic/4746/diagnostics-error . Funnily enough, you upvoted my reply there 🙂
        also see https://docs.cloudron.io/apps/matomo/#load-data-infile
        d19dotcaD 2 Replies Last reply
          d19dotcaD Offline
          d19dotcaD Offline
          d19dotca
          @girish haha, damn, I didn't remember that and didn't see it when I did a quick search for some reason, haha. Thanks Girish! 🙂
          Dustin Dauncey
          www.d19.ca
            d19dotcaD Offline
            d19dotcaD Offline
            d19dotca
            @girish So I was looking at this a bit more and found this: https://matomo.org/faq/troubleshooting/faq_194/
            Judging by the link above, it seems this can actually be fixed in the app package by setting this in the default config: enable_load_data_infile=0
            Right now, the package seems to have this enabled (or rather it's default enabled in Matomo) when it should be disabled with the setting above.
            Dustin Dauncey
            www.d19.ca
              @d19dotca Ah, great find! Let me add that to the package.
              d19dotcaD 1 Reply Last reply
                d19dotcaD Offline
                d19dotcaD Offline
                d19dotca
                @girish Seems the latest app package update fixes it. Thanks for the quick turnaround as always! 🙂
                Dustin Dauncey
                www.d19.ca
