  2. LAMP
  3. Mysql ssl error and auto-increment not working
Scheduled Pinned Locked Moved LAMP
7 Posts 4 Posters 2.8k Views 4 Watching
  • C Offline
    C Offline
    CarbonBee
    I have a strange behaviour with mysql in a Lamp container.
    Here is the backgroud:
    • I want to have this project https://partkeepr.org/ on my 2 servers
    • I requires php <= 7.1
    • I use lamp v1.4.0 https://git.cloudron.io/cloudron/lamp-app/-/tags/v1.4.0
    On one of my server (cloudron v6.0.1) it works fine.
    But on the other one (cloudron v6.2.8), I have many problems :
    • In the terminal, when I try to connect to mysql CLI, I've got the error ERROR 2026 (HY000): SSL connection error: unknown error number so I have to use phpmyadmin to make database manipulation,
    • When I insert a line in a table, the new id (an AUTOINCREMENT field) is correctly incremented, but in the information_schema fields, neither table_rows nor auto_increment etc... fields are modified. I have a trigger on before insert which needs the auto_increment value.
    I have never seen such a behaviour and don't really know what to do.
    Does anyone has any idea?
    nebulonN M 2 Replies Last reply
    • C CarbonBee
      @carbonbee not sure what that issue is. Maybe since you use some older app package, this is caused by mysql client/server version mismatch?
      Anyone else here has seen this?
      • C CarbonBee
        M Offline
        M Offline
        msbt
        @carbonbee at least for the first thing I've had a similar issue on a new cloudron and old LAMP, @girish suggested to just use another apps' terminal to connect to the db and do you alterations there.
          Right, please check the post that @msbt suggested. The main difference is that Cloudron 6.2 has MySQL 8 whereas Cloudron 6.0 is on MySQL 5.6. To connect to MySQL 8, you need the latest CLI tool because they have changed how authentication works.
          C 1 Reply Last reply
            C Offline
            C Offline
            CarbonBee
            @girish @msbt Thanks! This helped greatly.
            But I still have my increment issue.
            In the CLI, I can do ANALYZE TABLE <my_table> after an insert and it updates the information_schema fields (TABLE_ROWS, AUTO_INCREMENT,...).
            But when I insert again, nothing changes. I have to always make the ANALYZE TABLE to update the info.
            Have you ever encounter this?
            • C CarbonBee
              C Offline
              C Offline
              CarbonBee
              Ok, I managed to make the application working from a backup.
              The issue appears as soon as I connect to phpmyadmin.
              I don't really understand why and what happens, but as long as I stay away from phpmyadmin, everything works fine.
              • C CarbonBee
                @carbonbee don't think it matters but I will push an update to phpMyAdmin 5.1.0 - https://www.phpmyadmin.net/news/2021/2/24/phpmyadmin-510-released/
