  3. RediSearch
RediSearch
redisearchredis
6 Posts 3 Posters 2.2k Views 3 Watching
  • V Offline
    V Offline
    Vladimir
    Hello guys,
    Since Redis is already installed and preconfigured (atleast for WordPress unmanaged), is RediSearch installed and configured also?
    If not, do you have any info on how can I install and configure it?
    I found this quick start guide but I am not sure if it is relevant in the Cloudron case.
    https://oss.redislabs.com/redisearch/Quick_Start/
    • V Vladimir
      Hello guys,
      @vladimir redisearch is not installed or configured. I am not aware of any app requiring this. I guess if this is for a custom app, you will have to package this yourself - https://docs.cloudron.io/custom-apps/tutorial/
      V 1 Reply Last reply
        V Offline
        V Offline
        Vladimir
        @girish It doesn't require it.
        I just want to use the WordPress plugin RediSearch but I need to make additional configurations on the server, which I am not sure how to do with the Cloudron installation
        • V Vladimir
          @vladimir said in RediSearch:
          Can you clarify what doesn't require it? Are you referring to the plugin?
          What are the additional changes?
          I am not completely following your requirements. You are saying the plugin doesn't require redissearch but requires some other configuration changes?
            V Offline
            V Offline
            Vladimir
            @girish
            Hello girish,
            I am trying to install RediSearch plugin in my unmanaged WordPress app but it requires additional configuration on the server, which I am not sure how to approach with Cloudron. In a similar way, the WordPress unmanaged install Redis plugin but the configuration has been already made.
            d19dotcaD 1 Reply Last reply
            • V Vladimir
              @girish
              Hello girish,
              d19dotcaD Offline
              d19dotcaD Offline
              d19dotca
              @vladimir What other configurations are needed by redisearch though? I think it needs to be laid out specifically so that the amazing Cloudron team can figure out what can be safely added if any to the current redis server configuration, or if it's configurations needed within the WordPress server/app instead, etc. When you deploy redissearch, does it error on anything, what errors does it provide in the user interface and the logs for example?
              Dustin Dauncey
              www.d19.ca
