  2. WordPress (Developer)
  3. wp-cli not working on 6.3.5?
Scheduled Pinned Locked Moved WordPress (Developer)
13 Posts 2 Posters 5.6k Views 2 Watching
  • martinkbsM Offline
    martinkbsM Offline
    martinkbs
    Hi guys,
    After updating two Cloudrons I find the same problem in the WordPress (managed) installations.
    Connecting...
    If you resize the browser window, press Ctrl+D to start a new session with the current size.
    root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/code# wp plugin list
    bash: wp: command not found
    Anyone has encountered the same error?
    Thanks!
    • martinkbsM martinkbs
      Hi guys,
      Connecting...
      Thanks!
      @martinkbs I think same as https://forum.cloudron.io/topic/5382/wp-cli-disappeared . Can you try giving the full path?
      martinkbsM 1 Reply Last reply
        martinkbsM Offline
        martinkbsM Offline
        martinkbs
        @girish
        Reconnecting...
        root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/code# cd /app/pkg/wp
        bash: cd: /app/pkg/wp: Not a directory
        root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/pkg# ls
        authLdap.zip  credentials.template  cron.sh  mpm_prefork.conf  smtp-mailer.zip  start.sh  wp  wp-convert-multisite  wp-redis-cache.zip
        root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/pkg# wp plugin list
        girishG 2 Replies Last reply
          @girish
          Reconnecting...
          @martinkbs you have to either do /app/pkg/wp plugin list OR if you cd /app/pkg, then ./wp plugin list (the dot slash in the front is important).
            @girish
            Reconnecting...
            @martinkbs Is this managed wordpress or the developer wordpress ? The CLI command is slightly different depending on which one.
              martinkbsM Offline
              martinkbsM Offline
              martinkbs
              @girish
              With /app/pkg/wp plugin list
              With cd /app/pkg, then ./wp plugin list
              The installation is always WordPress (Developer)
                @girish
                @martinkbs you have to use the command like in https://docs.cloudron.io/apps/wordpress-developer/#wp-cli . So,
                sudo -E -u www-data php /app/pkg/wp --path=/app/data/public/ plugin list
                To explain the arguments:
                • sudo is for running the command as a different user. -u www-data means run it as www-data user (which is what apache is running as)
                • -E means to preserve environment variables. This way the container's env vars are passed on to the CLI command as well.
                • --path is required to specify the path to the installation of WP.
                  martinkbsM Offline
                  martinkbsM Offline
                  martinkbs
                  Hi @girish
                  WP-cli commands, up to version 6.3.X update have always worked the same way. In fact, I have several Cloudrons in version 6.2.8, in which the 'wp plugin list' command works as WP-cli has to.
                  According to your explanation, it means that from now on, in version 6.3.X you have to put the command as you mentioned?
                  Or is it going to restore the original format that was used until now? As you will see, it is not a very productive way to work with the terminal.
                    Hi @girish
                    @martinkbs you are right, there should be a wp command alias. I see that it's in the package code as well. Let me see why it broke.
                      It seems /root/.bashrc is not sourced for some reason. If you do, source /root/.bashrc , then wp starts to work. Investigating further.
                        I had made a change that source any app specific rcfile for 6.3. I did this for https://forum.cloudron.io/topic/4992/seting-bash-aliases-for-cloudron-terminal. Unfortunately, this breaks sourcing of the personal rcfile. From the man page,
                               --rcfile file
                                      Execute commands from file instead of the system wide initialization file /etc/bash.bashrc and the standard personal initialization file ~/.bashrc if the shell is interac‐
                                      tive (see INVOCATION below).
                        @martinkbs I will look into how to fix this now that I know what the issue is. Thanks for reporting! For the moment, the workaround is to type source /root/.bashrc after you open a web terminal and then the wp command should work.
                                 --rcfile file
                          martinkbsM Offline
                          martinkbsM Offline
                          martinkbs
                          Thanks @girish
                          Checked. After starting the terminal, inserting the commandsource /root/.bashrc, WP-cli works normally.
                          Connecting...
                          root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/code# source /root/.bashrc
                          root@2d2d8096-2889-44f0-b36b-0aed411943c6:/app/code# wp core version
                          5.8
                          At least, even temporarily, it solves the problem and lets you use the terminal.
                          If you need help, please let me know to make checks.
                          Thanks again!
                            I have fixed this for the next release.
                            With your input, this post could be even better šŸ’—
