  2. Nextcloud
  3. Speed tip for Nextcloud: The "Temporary files lock" add-on causes significant slowness
1 Posts 1 Posters 723 Views 1 Watching
  • marcusquinnM
    marcusquinnM
    We're doing some speed profiling and testing with Nextcloud, and found the "Temporary files lock" add-on causes significant slowness for the number of users and amount of data we have.
    We likely don't need that add-on, and the file versioning add-on pretty-much covers that overlapping save conflicts avoidance need.
    Some search terms for those that might also be having this issue: Nextcloud files root folder speed slow loading spinner issue problem fix.
    Hope that helps anyone else finding similar. Share the knowledge! And let us know any other speed tips you find in posts here too.
