  2. Gitea
  3. Need help to enable autosign
Scheduled Pinned Locked Moved Solved Gitea
27 Posts 5 Posters 20.0k Views 5 Watching
  • jaschaezraJ Offline
    jaschaezraJ Offline
    jaschaezra
    Hi!
    I wanted to enable autosign and ran in an issue I can not solve.
    I set the .gnupg folder for the git-User
    export GNUPGHOME=/app/data/appdata/home/.gnupg
    created keys and everything.
    But: The moment Gitea wants to sign a commit it fails as I have no possibility to set GNUPGHOME. .
    Maybe anyone has an idea.
    • jaschaezraJ jaschaezra
      Hi!
      @jaschaezra we may have to add support for that in the packaging then. Do you have a link to a tutorial or docs on how to setup the auto-signing?
      jaschaezraJ 1 Reply Last reply
        jaschaezraJ Offline
        jaschaezraJ Offline
        jaschaezra
        @nebulon That would be great.
        there is no real tutorial, the documentation is quite...vague. it is here: https://docs.gitea.io/en-us/signing/
        What needs ti be done (and not written down in the documentation): create a password less key.
        I normaly do it like this:
        change to the git User (su git)
        create file 'genkey-batch':
        %no-protection
        Key-Type: default
        Subkey-Type: default
        Name-Real: Gitea
        Name-Email: git@GITEADOMAIN
        Expire-Date: 0
        Execute key generation:
        gpg --batch --gen-key genkey-batch
        the Key will be added to the keychain which resides in /home/$USER/.gnupg
        You can change this with
        In the app.ini you need to add the following:
        [repository.signing]
        SIGNING_KEY = default
        SIGNING_NAME = Gitea
        SIGNING_EMAIL = git@GITEADOMAIN
        INITIAL_COMMIT = always
        CRUD_ACTIONS = pubkey, twofa, parentsigned
        WIKI = never
        MERGES = pubkey, twofa, basesigned, commitssigned
        The last three entries can and should be configured by the Instance Gitea-Owner, depending on what should be auto signed.
        the only thing which needs to be changed if you do it like I did is to add
        to the shell environment. then it works (well, it did on my old server with other paths, but it worked :))
        the only thing I would do if I package would be to add GNUPGHOME as standard and add a note in the documentation how to enable autosign.
          Thanks for the detailed description. I have changed the package to allow adding the keys and set the GNUPGHOME (this change is not published yet). It all seems fine, but I am not sure how to test or check if the signing actually was performed. Also do I have to set something for a git repository in gitea specifically to make it sign the commits?
            jaschaezraJ Offline
            jaschaezraJ Offline
            jaschaezra
            @nebulon I would love to test it. 🙂
            When you create a repository and init it from the webfrostend, then this commit is signed by Gitea. So in fact all the things you do in the webfrontend.
            These settings
            INITIAL_COMMIT = always CRUD_ACTIONS = pubkey, twofa, parentsigned
            say: Always sign the initial commit. Sign every other commits if the User has set a pub key OR enabled TFA or if the parent commit is signed.
            Hope that helps.
              These settings
              Hope that helps.
              @jaschaezra the change is quite small https://git.cloudron.io/cloudron/gitea-app/-/commit/32eebcff8fd7c095d4e88cba396e693cb12bfbbe
              It would be great if you could test this. Basically checkout the app package repo and run cloudron build && cloudron install in the folder. Granted you have the cloudron cli tool installed and configured for your Cloudron already.
              jaschaezraJ 3 Replies Last reply
                jaschaezraJ Offline
                jaschaezraJ Offline
                jaschaezra
                wrote on last edited by jaschaezra
                @nebulon Thanks! I will test it later tonight and provide feedback!
                EDIT How do I build it? cloudron build asks for a registry...
                  jaschaezraJ Offline
                  jaschaezraJ Offline
                  jaschaezra
                    jaschaezraJ Offline
                    jaschaezraJ Offline
                    jaschaezra
                    @nebulon I got the image built but I can not install it.
                    Port SSH_PORT: 29418
                    Failed to install app: 409 message: Port 29418-tcp is in use```
                      @jaschaezra seems like you already have an instance using the default port there. Try to run cloudron install -p for interactive way to set a different port.
                        jaschaezraJ Offline
                        jaschaezraJ Offline
                        jaschaezra
                        @nebulon I do not know what is going on on my system but I seriously fucked something up 😞
                        Sorry, I just can not test it at the moment 😞
                          @jaschaezra there is no time pressure at all. Hope you get your system back up again though. If it is Cloudron related, let us know of course.
                            jaschaezraJ Offline
                            jaschaezraJ Offline
                            jaschaezra
                            @nebulon It worked for me 🙂
                            So it would be great if this can be deployed in the container. (With the latest update :D)
                              @jaschaezra thanks for testing and confirming the fix. I have pushed a new package now.
                                jaschaezraJ Offline
                                jaschaezraJ Offline
                                jaschaezra
                                @nebulon I just want to add some screen I just made because I forgot them to create 😄
                                This is how you'll see it in the repository:
                                When you take a look at the commit:
                                The name is set in app.ini
                                For the key-creation:
                                It is much easier to do it like this:
                                gpg --default-new-key-algo rsa4096 --gen-key
                                then enter the Name, the Email (git@DOMAIN) and NO password!
                                That's it.
                                  That's it.
                                  jaschaezraJ Offline
                                  jaschaezraJ Offline
                                  jaschaezra
                                  @jaschaezra BTW, you can set a Gravatar/Libravatar for git@DOMAIN and upload e.g. the gitea Logo which then is displayed.
                                    jaschaezraJ Offline
                                    jaschaezra
                                    This is odd - after working for a looong time I suddenly get this error when creating a repository and initializing it:
                                    CreatePost, initRepository: initRepoCommit: git commit: exit status 128 - error: gpg failed to sign the data
                                    fatal: failed to write commit object
                                    I first thought that maybe the key is gone. By checking this I found that:
                                    root@0f44f577-d0e0-42e6-a371-d3914aba0014:/home/git# sudo -u git gpg --list-keys
                                    gpg: Fatal: can't create directory '/home/git/.gnupg': Read-only file system
                                    I have not changed anything and I do not know when this happened as I was not using my git for the last ~9 months.
                                    Any idea what is going on @nebulon?
                                      Just briefly rereading the thread, did you set GNUPGHOME for git user so it uses the correct (writeable) folder? Seems like the one which is used should be export GNUPGHOME=/app/data/appdata/home/.gnupg
                                      robiR jaschaezraJ 2 Replies Last reply
                                        @nebulon might be nice to have these set when terminal is launched including HOME.
                                          jaschaezraJ Offline
                                          jaschaezraJ Offline
                                          jaschaezra
                                          @nebulon I now get a new error:
                                          root@0f44f577-d0e0-42e6-a371-d3914aba0014:/home/git# sudo -u git bash
                                          git@0f44f577-d0e0-42e6-a371-d3914aba0014:~$ export GNUPGHOME=/app/data/appdata/home/.gnupg
                                          git@0f44f577-d0e0-42e6-a371-d3914aba0014:~$ gpg --list-keys
                                          gpg: WARNING: unsafe permissions on homedir '/app/data/appdata/home/.gnupg'
