  2. Gitea
  3. Need help to enable autosign
Scheduled Pinned Locked Moved Solved Gitea
27 Posts 5 Posters 21.7k Views 5 Watching
    The permissions can be fixed up with:
    chmod 600 /app/data/appdata/home/.gnupg/*
    chmod 700 /app/data/appdata/home/.gnupg
    However, this is also only a warning, not sure if this is the root cause. Are there any keys in the folder itself?
    • jaschaezraJ Offline
      jaschaezraJ Offline
      jaschaezra
      Oh, no, my key is gone. That is odd as I never touched the key after it worked.
        jaschaezraJ Offline
        jaschaezra
        wrote on last edited by jaschaezra
        #23
        After creating a new key and configuring it in app.ini and restarting gitea I still get an error:
        root@0f44f577-d0e0-42e6-a371-d3914aba0014:/home/git# sudo -u git bash
        git@0f44f577-d0e0-42e6-a371-d3914aba0014:~$ export GNUPGHOME=/app/data/appdata/home/.gnupg
        git@0f44f577-d0e0-42e6-a371-d3914aba0014:~$ gpg --list-keys
        /app/data/appdata/home/.gnupg/pubring.kbx
        pub   rsa4096 2025-01-21 [SC] [expires: 2027-01-21]
              EF80C8DE297670B7E8C0360108DA2115185FFD9C
        uid           [ultimate] jascha.wtf Gitea <git@git.jascha.wtf>
        section of app.ini:
        [repository.signing]
        SIGNING_KEY = EF80C8DE297670B7E8C0360108DA2115185FFD9C
        SIGNING_NAME = jascha.wtf Gitea
        SIGNING_EMAIL = git@git.jascha.wtf
        INITIAL_COMMIT = always
        CRUD_ACTIONS = pubkey, twofa, parentsigned
        WIKI = never
        MERGES = pubkey, twofa, basesigned, commitssigned
        GITEA__REPOSITORY__ENABLE_PUSH_CREATE_USER=true
        From the log:
        Jan 21 10:45:28 Error: exit status 128 - error: gpg failed to sign the data
        Jan 21 10:45:28 fatal: failed to write commit object
        Jan 21 10:45:28 - error: gpg failed to sign the data
        Jan 21 10:45:28 2025/01/21 09:45:28 ...ers/web/repo/repo.go:217:handleCreateError() [E] CreatePost: initRepository: initRepoCommit: git commit: exit status 128 - error: gpg failed to sign the data
        Jan 21 10:45:28 2025/01/21 09:45:28 ...eb/routing/logger.go:102:func1() [I] router: completed POST /repo/create for 82.140.42.234:0, 500 Internal Server Error in 55.3ms @ repo/repo.go:222(repo.CreatePost)
        Update: Gitea does not get the signing key. The response of https://git.jascha.wtf/api/v1/signing-key.gpg is empty
        My best guess is that there are some path poblems - https://docs.gitea.com/administration/signing
          jaschaezraJ Offline
          jaschaezra
          Oh, forgot to mention @nebulon
            @jaschaezra are your GPG keys password protected ? (See also https://docs.gitlab.com/ee/user/project/repository/signed_commits/gpg.html#gpg-fails-to-sign-data)
            • jaschaezraJ jaschaezra
              section of app.ini:
              WIKI = never
              From the log:
              @jaschaezra said in Need help to enable autosign:
              Did a quick test. Setting GNUPGHOME env var makes it work. You can use CLI tool for this cloudron env set GPGHOME=/app/data/appdata/home/.gnupg . But I think we should set this in the package itself.
                Well, I am confused. For me, it works out of the box. See this comment from @nebulon - https://forum.cloudron.io/post/55637
                • GNUPGHOME is already to /app/data/gnupg
                • Just put your keys in above directory
                • curl https://gitea.domain.com/api/v1/signing-key.gpg works
                • Create empty repo.
