  3. Haproxy
Haproxy
11 Posts 5 Posters 3.1k Views 4 Watching
  • H Offline
    H Offline
    herculist2022
    Haproxy free version
    H 1 Reply Last reply
    • H herculist2022
      H Offline
      H Offline
      herculist2022
      http://www.haproxy.org/
      fbartelsF 1 Reply Last reply
      • H herculist2022
        fbartelsF Offline
        fbartelsF Offline
        fbartels
        @herculist2022 what would like want to do with it on Cloudron?
        • fbartelsF fbartels
          H Offline
          H Offline
          herculist2022
          @fbartels load balancer and reverse proxy websites or other services
          murgeroM fbartelsF 2 Replies Last reply
          • H herculist2022
            murgeroM Offline
            murgeroM Offline
            murgero
            @herculist2022 Feel like if you wanna load balance with cloudron, a second server would be needed + the load balancer should be on it's own hardware or vps to prevent ddos.
            https://urgero.org
            • H herculist2022
              fbartelsF Offline
              fbartelsF Offline
              fbartels
              @herculist2022 Cloudron is already using nginx as a reverse proxy (for http requests) and with the latest release also can expose applications on other hosts through it.
                H Offline
                H Offline
                herculist2022
                @fbartels said in Haproxy:
                nginx
                nginx is something different from haproxy
                • H herculist2022
                  nginx
                  H Offline
                  H Offline
                  herculist2022
                  @herculist2022 said in Haproxy:
                  nginx
                  HAProxy is open-source software that supports load-balancing capabilities and focuses on improving performance. NGINX is an open-source web server that comprises HTTP server capabilities and focuses on delivering stability and better performance results.
                  https://cloudinfrastructureservices.co.uk/haproxy-vs-nginx-whats-the-difference/
                  • njN Offline
                    njN Offline
                    nj
                    Alright, I will be the rude one here.
                    • Haproxy is a loadbalancer software with many features already offered by nginx.
                    • Cloudron uses nginx instead of haproxy and it's now too much work to switch to haproxy
                    • Haproxy cannot be an "app" on cloudron because it is basically a load-balancer service, that's all.
                    Yes, one could package haproxy as an app but what's the purpose of it? Do you want to open the app's terminal and add loadbalancing configuration? Haproxy will be running behind Cloudron's nginx, so it won't be at the best position to be serving as a loadbalancer.
                    Founder / Coder • My Apps
                    H robiR 2 Replies Last reply
                    • njN nj
                      H Offline
                      H Offline
                      herculist2022
                      @nj nobody said shutdown nginx
                      only we ask if can add haproxy also
                      somebody may want haproxy alone
                      others nginx alone
                      others both
                      and others none
                      so simple
                      it is an addition
                      now if its a lot of work ... just prioritize
                      • njN nj
                        @nj there are still useful use cases for having something load balanced within cloudron, such as having multiple vpn services and load/connection balancing across them.
                        So Nginx to HAproxy to any number of other apps you want control traffic to.
                        Ideally you could set that up with Nginx, but that's a feature that may become important to the CL team once v8 introduces multi server support.
