  2. Surfer
  3. Custom Cache-control headers
Scheduled Pinned Locked Moved Surfer
8 Posts 4 Posters 4.0k Views 3 Watching
  • njN Offline
    njN Offline
    nj
    wrote on last edited by nj
    The header currently sent by Surfer for all requests is Cache-Control: public, max-age=0
    This setting causes the browsers to re-request everything that could have been cached instead. If the max-age value could be customizable from settings or somehow else, that would be a lot less strain on the Surfer on Cloudron.
    My use-case:
    I run Surfer behind Cloudflare, and Cloudflare honors the cache settings, but only if max-age is set to a non-zero value. Basically Cloudflare is not caching anything and my Surfer instance is constantly running out of memory because of the number of requests.
    Founder / Coder • My Apps
    • njN Offline
      njN Offline
      nj
      @staff
      Tagging for visibility of the post.
        I think that makes sense, currently it uses the express.static() defaults only.
        • marcusquinnM Offline
          Even a setting of a few seconds is useful
            So surfer already sets the ETag https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/ETag but no max-age The max-age setting basically makes the browser not even check in the with server if the content may have changed.
            Now various frameworks set the max-age very high and use other cash busting techinques (like changing the file path hash) to serve up-to-date content if needed.
            For surfer this is hard to implement, as the main html pages have to be aware of this. So I am not sure how surfer can set max-age and ensure that content is fresh at the same time.
              Given that this is CloudFlare acting as a browser here, I wonder if they have cache settings on their own to for example mark a subpath of the proxied app as valid for n seconds?
                In theory , max-age=0 means the same as no-cache . no-cache means cache it but always revalidate. It seems max-age=0 allows stale reuse and thus there is also a must-revalidate to prevent that.
                Cloudflare has it's own interpretation. Per https://developers.cloudflare.com/cache/about/default-cache-behavior , it won't cache at all with max-age=0. We have to create a custom page rule - https://developers.cloudflare.com/cache/how-to/create-page-rules/ to override the default caching behavior.
                So... my interpreation is that we need Cache-Control: public, max-age=1, must-revalidate if we want this to work out of the box in Cloudflare.
                  https://learn.microsoft.com/en-us/azure/cdn/cdn-how-caching-works is an excellent read on some other interpretations.
