  2. WordPress (Developer)
  3. Running optimize on DB tables for WP shows errors about invalid default values
Scheduled Pinned Locked Moved WordPress (Developer)
3 Posts 2 Posters 2.1k Views 2 Watching
  • d19dotcaD
    d19dotcaD
    d19dotca
    I stumbled across something a bit strange... some tables by default in a brand new WP app install show errors around invalid default values for some table columns. I had seen this on a few of my own sites but realized some of mine also seem to have a mix of storage types and such, so spun up a fresh one to compare and try to bring my affected ones in line, but noticed these errors occur on a fresh one too. Is this expected? I kind of wonder if the DB defaults aren't set correctly somehow for default values.
    Thoughts?
    19558a605fe34e5e.wp_commentmeta
    note     : Table does not support optimize, doing recreate + analyze instead
    status   : OK
    19558a605fe34e5e.wp_comments
    error    : Invalid default value for 'comment_date'
    status   : Operation failed
    19558a605fe34e5e.wp_links
    error    : Invalid default value for 'link_updated'
    19558a605fe34e5e.wp_options
    status   : OK
    19558a605fe34e5e.wp_postmeta
    status   : OK
    19558a605fe34e5e.wp_posts
    error    : Invalid default value for 'post_date'
    19558a605fe34e5e.wp_term_relationships
    status   : OK
    19558a605fe34e5e.wp_term_taxonomy
    status   : OK
    19558a605fe34e5e.wp_termmeta
    status   : OK
    19558a605fe34e5e.wp_terms
    status   : OK
    19558a605fe34e5e.wp_usermeta
    status   : OK
    19558a605fe34e5e.wp_users
    error    : Invalid default value for 'user_registered'
    Success: Database optimized.
    Dustin Dauncey
    www.d19.ca
      I don't see an error in a fresh instance but I can guess the source of the error.
      I think this is related to values in the "date" fields. This is controlled by sql_mode .
      mysql>    SELECT @@sql_mode;
      | @@sql_mode        |
      | ONLY_FULL_GROUP_BY,STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION |
      1 row in set (0.00 sec)
      The NO_ZERO_IN_DATE,NO_ZERO_DATE mean that 0 value is not a valid date. This is the default in recent SQL versions (but wasn't in MySQL 5.x iirc).
      You can set the sql_mode for the session like so:
      mysql> set sql_mode = 'ONLY_FULL_GROUP_BY,STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION';
      Query OK, 0 rows affected, 1 warning (0.00 sec)
      Maybe try running optimize afterwards? Also, I think sql_mode does not affect existing data, so you might have to fix them manually to make it work by default with the latest sql_mode .
      d19dotcaD 1 Reply Last reply
        | @@sql_mode        |
        d19dotcaD
        d19dotcaD
        d19dotca
        @girish strange that you don’t see that error on a fresh instance, that’s how I reproduced the problem before to compare a fresh DB with my used ones and noticed it on the fresh one too. I’ll look into that further. Thanks 😊
        Dustin Dauncey
        www.d19.ca
