  2. SOGo
  3. "Discard incoming mails during vacation" does not work
Scheduled Pinned Locked Moved Solved SOGo
2 Posts 1 Posters 1.2k Views 1 Watching
  • luckowL
    luckowL
    luckow
    Expected behavior: No mails are delivered to the inbox, instead mails are accepted.
    Is there anyone else for whom this function does not work?
    luckowL 1 Reply Last reply
    • luckowL luckow
      luckowL
      luckowL
      luckow
      @luckow Maybe the doc should be a bit clearer. SoGo is "nothing else" than a kind of webmailer for Cloudron. Since Cloudron's built-in mail server is in the foreground, it intercepts the mails and only after that SoGo replies with a vacation auto-response. No chance for SoGo to throw away the mail.
      UPDATE:
      Adding a rule, solves the unexpected behavior.
      Now it sends the vacation auto reply AND discards the message.
      • luckowL luckow marked this topic as a question on
      • luckowL luckow has marked this topic as solved on
