  3. ChatPad on Cloudron - ChatGPT Artificial Intelligence Interface
chatpadchatgptartificialintel
26 Posts 5 Posters 11.6k Views 10 Watching
  • KubernetesK Kubernetes
    @timconsidine Interesting tool, I tried, but first attempts did fail because of the read-only filesystem in Cloudron...
    @Kubernetes I am trying also but running into errors
    Will try again later
      #22
      @Kubernetes said in ChatPad on Cloudron - ChatGPT Artificial Intelligence Interface:
      Shhhh, don't tell @girish or @nebulon but sometimes I try to "bypass" this issue to get a proof of concept by installing to /app/data
      Just to see it if builds and works.
      Then think about separation of code and data
        Okay, I have done it. The package is ready from my point of view and could be published in Cloudron App Store.
        Thanks to all for the feedback and support.
        Well done 🍾
        I have a built the package, it installed smoothly and runs nicely.
        Thank you for your work on this. I may stop using the desktop version.
        The Docker image is large : 5Gb. Surprised me (but heck, what do I know).
        I wonder if there is a way to reduce the size of the image during the build process.
        But I am no expert in Docker, so not sure.
        I didn't see anything obvious in the Docker file.
        Maybe a multi-stage build ? But I don't much about that.
        • KubernetesK
          KubernetesK
          Kubernetes
          wrote on last edited by Kubernetes
          #24
          I moved the repo to the Cloudron Gitlab
          Regarding size, 5Gb is really big. But maybe someone with experience in shrinking the Docker images can give some advise.
          • KubernetesK
            KubernetesK
            Kubernetes
            I have updated the Dockerfile to remove unrequired software and use of multi stage for build and production.
              @Kubernetes oooo ! Will take a look
