  3. CPU stuck and using all cores at 100%
cpumysql
5 Posts 3 Posters 2.1k Views 4 Watching
    jonslab
    I am stumped. Is there any way to actually get more information about what is causing the CPU to spike?
    I want to know what service is causing the issue.
    I have tried looking at processes using htop and cgtop.
    Using htop, it looks like mysql is using all of the cpu, but when using cgtop, I get the following results.
    I have also tried using phpmyadmin to view any processes running in mysql, but I do not see any processes out of the norm there either.
    The only way to get the spike to drop is to reboot cloudron entirely. Restarting the app I am using does not fix the problem. Makes me think it is an issue with cloudrons sql.
    Any suggestions would be super helpful!
    • J jonslab
      @jonslab if it's mysql, it's probably to do with swapping. Go to Services -> MySQL and give MySQL lot more memory.
      J 1 Reply Last reply
        jonslab
        wrote on last edited by jonslab
        @girish We made sure it has plenty of memory. Unfortunately it is not a SWAP issue.
        I will keep diving into this and will post any updates as I find more details on the issue.
          what all apps do you have installed that use mysql?
          • J jonslab
            @jonslab did you find what it was?
