  2. Nextcloud
  3. Nextcloud not responding
23 Posts 3 Posters 10.0k Views 3 Watching
    Turns out while that storage volume has the issue it was not really used.
    The issue was that /app/data/config/config.php has the data directory set to /app/code/data instead of /app/data . Not sure how this happened. But resetting that config value makes it come up again.
    T 1 Reply Last reply
      @tadeas it seems permissions don't work on the volume . It's also mounted by via sshfs/fuse. I am not sure how well this works. Any reason not to use NFS if it is block storage?
      # chown root /mnt/storage_box/xx
      chown: changing ownership of 'xx': Permission denied
      T
      T
      tadeas
      @girish I think this was a working solution two years ago and I have not touched it since then. It was only used to mount a directory so that it would be visible form Nextcloud. While looking for a solution I have removed it from nextcloud so that's why it was not used.
        T
        T
        tadeas
        @girish Thanks a lot, i did not notice that.
