B
Bob_247
@Bob_247
Unfollow Follow
Posts
Topics
Shares
Groups
Followers
Following
Posts
Recent Best Controversial
  • After CPU limit change : Docker Error: (HTTP code 400) bad parameter,
    B Bob_247
    okk great, did, and works back !
    Thanks !
    Support docker cpu
    B Bob_247
    hi, i just did, here's the output : +----------+
    | cpuQuota |
    | 100 |
    | 100 |
    | 69 |
    | 100 |
    | 100 |
    No fractional values, every other app is at 100, the 69 is what i wanted to set for n8n
    Support docker cpu
    B Bob_247
    Hello, i recently changed the CPU use limit n8n can use, since then the parameter can't get applied and the app is in constant error mode.
    I have tried restoring a backed up version, but it wont change.
    Here's the error i cant gest past : "Docker Error: (HTTP code 400) bad parameter - invalid JSON: json: cannot unmarshal number 8279999999.999999 into Go struct field HostConfig.HostConfig.NanoCpus of type int64"
    Any idea on hove to solve it ?
    Thanks for your help !
    Support docker cpu
