  2. Nextcloud
  3. Nexcloud Hub 7 (v 28) is out
16 Posts 5 Posters 5.3k Views 5 Watching
  • necrevistonnezrN Offline
    Seems like a small improvements release: Better search, 65 % faster files app (migrated to vue.js), more AI.
    See details at: https://nextcloud.com/blog/nextcloud-hub-7-advanced-search-and-global-out-of-office-features/
    As usual, won’t appear at your Cloudron before the first bugfix release (28.01 or similar) πŸ™‚
      Yes, we most likely will wait for the first patch release, also to let Nextcloud plugin authors catch up.
      I have done some smoke testing though with 28 and it appears to work fine.
      G 1 Reply Last reply
      • andreasduerenA Offline
        andreasdueren
        F*cking finally lol
          G Offline
          G Offline
          giofonseca
          @nebulon https://nextcloud.com/blog/quick-patch-for-hub-7-is-available/
          πŸ˜‰
            We are on it, things are a bit slow here till year end and the package needs some fixing for it
              While working on the app package, where I am trying to get the nextcloud logviewer working, I found that it always errors if ublock is used: https://github.com/nextcloud/logreader/issues/1058
              This is not really fatal, but looks wrong.
                FYI: 28.0.1 is released:
                https://github.com/nextcloud/server/releases/tag/v28.0.1
                https://nextcloud.com/changelog/
                  There are still some glitches with 28.0.1 some basic UI oddities like the welcome wizard has two independent close buttons but also some startup warnings.
                  One such issue is https://github.com/nextcloud/server/issues/34919 which is marked as fatal but actually its working fine. Similar to an error shown for a directory which does get created a bit later. Looks like we should not be too hasty to push an update.
                    Another bug reported now https://github.com/nextcloud/server/issues/42509
                    This results in an error, but actually it is not crucial, so maybe we release it even without that bug being resolved.
                    • S Offline
                      S Offline
                      skeats
                      Any updates on the release of Nextcloud Hub 7 v28?
                        https://nextcloud.com/changelog/#27-1-6
                        Nextcloud 27.1.6 is out as well….
                        28.0.2 is around the corner (coming on Tuesday, currently at RC4)
                          Yes, we will probably release it then, despite the kind of basic issue I reported on Github, but it doesn't look like upstream cares much.
                            New package is released now. We will still only slowly push it out for auto updates.
                                28.03 is out: https://nextcloud.com/changelog/#28-0-3
                                  It is in testing currently...
