  3. OwnTracks
OwnTracks
8 Posts 6 Posters 4.3k Views 8 Watching
    OwnTracks allows you to keep track of your own location. You can build your private location diary or share it with your family and friends. OwnTracks is open-source and uses open protocols for communication so you can be sure your data stays secure and private.
    • http://owntracks.org
    • http://owntracks.org/booklet/
    • https://philipp.adelt.net/5/posts/2015/06/owntracks-getting-started-private-mode/index.html
    • https://github.com/padelt/docker-owntracks-private-mqtt-broker
    T 1 Reply Last reply
    14
      T
      T
      timka
      @nebulon
      This would be really great 🙂 (Also it may be a old request)
      • M
        moonmeister
        This would be great.
        • necrevistonnezrN
          necrevistonnezrN
          Super Fan
          Is this still on everyone's radar? I just came across an article at Heise describing the server software in the iOS and Android app in great detail... https://www.heise.de/ratgeber/Den-eigenen-Standortverlauf-aufzeichnen-und-anzeigen-ohne-Google-9761016.html (€€)
          • J
            There is an initial package at https://git.cloudron.io/cloudron/owntracks-app . It will get published eventually .
            • necrevistonnezrN
              necrevistonnezrN
              Super Fan
              Wow, great!
                We were just looking into this app package to decide where to go. So the app itself works well, however only in MQTT mode and here without encryption.
                Further there is some concept of users and auth, but it realies on account duplication between nginx (for basic auth) and mosquitto. On top of this the actual frontend (the UI where you can see users and their devices) needs to be also protected. For that only the proxy auth in front of it is there, however that adds another layer of accounts (the accounts on cloudron) on top of the other accounts.
                On top of all this, if device location wants to be shared between users, those have to share their password/secret or new sets of secrets have to be generated per "view". A view is a separate html frontend tailored to show ownly selected devices.
                Given that there is also no UI for any of this, we will probably not publish the app. Too easy to get wrong and too many sets of user/passwords involved to be more than a geeky tool in my opinion.
                humptyH 1 Reply Last reply
                  humptyH
                  humptyH
                  humpty
