  3. Omeka - platform for digital cultural heritage web publishing
46 Posts 6 Posters 17.0k Views 8 Watching
    @jeau I've now pushed it as unstable for a start to collect further feedback.
    Regarding the LDAP tests, I have to take a closer look as well how to do that. If you are just concerned about the username/password, then we usually follow the pattern that you run the tests with a USERNAME and PASSWORD env variable locally against a test Cloudron. But since we have the package now in the store, we will test new releases from here on on our test Cloudrons anyways.
    imc67I
    imc67I
    imc67
    wrote on last edited by imc67
    #41
    @nebulon @jeau I just installed the app from the appstore and discovered after activating the LDAP module indeed as @girish wrote earlier a "strange" username and email.
    However after trial and error I succeeded to make it very workable:
    The 2 attributes were empty after activating and as you see with just those 2 LDAP attributes is works fine!!
    For new users it might be an idea to activate the module on install and fill the fields with those to attributes?
    jeauJ 1 Reply Last reply
    • imc67I imc67
      jeauJ
      jeauJ
      jeau
      @imc67 thank's for testing.
      I mentioned in the documentation that you have to activate and configure the Ldap module manually. But I forgot write this in the postinstall file in order to make this information visible immediately after installation. I just did it.
      I'll investigate to activate the module automatically. However I hesitate to operate directly in the database. I'll ask on the Omeka forum
      imc67I 1 Reply Last reply
      • jeauJ jeau
        imc67I
        imc67I
        imc67
        @jeau thanks!!!!
        • imc67I imc67
          @jeau thanks!!!!
          jeauJ
          jeauJ
          jeau
          @nebulon I updated the code with this information about the activation and configuration of the Ldap module. On the app store the Forum and Documentation links refer to the same page.
          • jeauJ jeau
            @jeau thanks, I will publish it then again.
              I will lock this topic in favor of the new forum section for the app at https://forum.cloudron.io/topic/5097/omekas-package-updates
              • nebulonN nebulon locked this topic on
