  3. SuiteCRM
SuiteCRM
24 Posts 10 Posters 10.2k Views 11 Watching
    Would be useful to my shop and I expect many others. https://suitecrm.com/
      This was posted by some on chat yesterday (https://paste.cloudron.io/raw/upesuzizis)
      • install an empty LAMP stack
      • download and extract SuiteCRM from https://suitecrm.com/download/ (upload either via sftp or wget and unzip in terminal) in /app/data/public
      • depending on how you got the files there, you need to do a "chown -R www-data:www-data /app/data/public" so it is able to write the config files
      • get environment variables in terminal with env | grep MYSQL_ and install SuiteCRM as you usually would
      • login with the newly created admin account and go to Admin -> Password Management, select" Enable LDAP Authentication" and enter at least the following information:
        • Server: 172.18.0.1
        • Port: 3002
        • User DN: ou=users,dc=cloudron
        • Bind Attribute: dn
        • Login-Attribute: username
      • give it a try if it's working, if it does, do a vi /app/data/public/config.php and replace the static db infos with the environment variables like so:
        array (
        'db_host_name' => getenv("MYSQL_HOST"),
        'db_host_instance' => 'SQLEXPRESS',
        'db_user_name' => getenv("MYSQL_USERNAME"),
        'db_password' => getenv("MYSQL_PASSWORD"),
        'db_name' => getenv("MYSQL_DATABASE"),
        'db_type' => 'mysql',
        'db_port' => getenv("MYSQL_PORT"),
        'db_manager' => 'MysqliManager',
      • save and see if everything is still working
        (Matthias also said) Ah yes, that was me. Additional note: If you migrate an existing installation, make sure to enable LDAP login on every user (in advanced settings) and of course check "Auto Create Users" in password settings, that should get you going.
          http://www.jsmackin.co.uk/suitecrm/suitecrm-command-line-install/ has some interesting information on automated installs
          • ? Offline
            ? Offline
            [[global:former-user]]
            SuiteCRM - Wikipedia
            https://en.wikipedia.org/wiki/SuiteCRM
            Open Source Self-Hosted SuiteCRM Alternatives
            https://alternativeto.net/software/suitecrm/?license=opensource&platform=self-hosted
            • doodlemania2D Offline
              doodlemania2
              Anyone made any progress packaging this up?
                Yes, @doodlemania2
                https://git.cloudron.io/cloudron/suitecrm-app is in decent shape. Still requires some finishing touches (https://git.cloudron.io/cloudron/suitecrm-app/issues). You can test it out!
                ? 1 Reply Last reply
                  Yes, @doodlemania2
                  ? Offline
                  ? Offline
                  @girish
                  Have you added the imap support in the container? I have installet SuiteCRM in an LAMP Container but i cannot acces IMAP. Missing addon ?
                    Yeah, the IMAP support is not added yet. I will try to fix it up - https://git.cloudron.io/cloudron/suitecrm-app/issues/2
                    • BenoitB Offline
                      BenoitB Offline
                      Benoit
                      Very interested by this app. I try EspoCRM at the moment and i'm not very happy with its design. Do you think it will be available soon ? Thanks @girish for your amazing work.
                        Currently, we are a bit tied with Cloudron 3.3. We will get this out immediately after.
                        • BenoitB Offline
                          BenoitB Offline
                          Benoit
                          Thanks Girish. take your time.
                          • darkbenD Offline
                            darkbenD Offline
                            darkben
                            hi, @girish do you think you can add SuiteCRM in Cloudron soon ? Thanks !
                            • marcusquinnM Offline
                              Any more thoughts on this?
                              I'm looking at the Mautic integrations and this is the only reasonable FOSS options I can see (SugarCRM integrations should work as that's what it used to be).
                              Or any other CRM recommendations welcome. Maybe Odoo or ERPNext would cover this need?
                              EspoCRM seems to have a big leap in costs for some of the paid features, which might be a bit much for some users.
                                Last we tried it, SugarCRM is a real pain to package 😞 The module system does not like symlinks and thus makes it tricky to upgrade. That said, we will do whatever is required on platform side to get popular apps...
                                  @girish Fair enough. Last time I tested it, it was SugarCRM and it was pretty flexible because the admin made almost everything customisable — but I haven't tested since, so couldn't say if it's "the best" FOSS CRM. I think it will work well enough for most though, and does have that long history so a few other apps do offer integration with it.
                                  Although, every popular app you have is another community of users that are self-hosting that app that will then find the advantages of Cloudron consolidation and standardisation of dev-ops & sys admin.
                                    • https://suitecrm.com/sugarcrm-loses-and-open-source-wins/
                                    • chrisC chris referenced this topic on
                                        • Port: 3002
                                        array (
                                      andreasduerenA Offline
                                      andreasdueren
                                      @girish I'm trying to set up LDAP with SuiteCRM in a LAMP stack here but can't get it to work somehow. Are you still using this setup?
                                        @andreasdueren I haven't tried this in ages (since I posted it). What error are you getting ?
                                          andreasdueren
                                          @girish Unfortunately it doesn’t have a test button and won’t show me log data so I’m just opening a new inkognito window to try out the login and I can’t really troubleshoot.
                                          I’m probably entering some incorrect setup information but I don’t know which one…
