  2. Audiobookshelf
  3. Using cli to administrate?
Scheduled Pinned Locked Moved Audiobookshelf
9 Posts 2 Posters 4.0k Views 2 Watching
  • KubernetesK Offline
    KubernetesK Offline
    Kubernetes
    Hi there,
    does someone knows if there is a cli available to manage Audiobookshelf?
    I would like to do at least one of those things:
    • Changing the media path
    • Reset admin passwort
    • Add admin privileges to an existing user
    Thanks for any hint. In the official documentation I didn't find anything related.
      Uhm, it's a node app, no cli like a compiled language.
      Paths are set via docker volumes. So change it via the CL App UI
      Users seem to be managed via api: https://api.audiobookshelf.org/#update-a-user
        KubernetesK Offline
        Kubernetes
        hm, I did a fresh install, was the easiest solution for me 😄
          KubernetesK Offline
          Kubernetes
          wrote on last edited by Kubernetes
          btw, I have problems using the iOS App (Testflight version as it is not in the app store) to login to Audiobookshelf via the Cloudron Login. I get an "OpenID Connect Error" because redirect_url did not match any of the client's registered redirect_urls
          • KubernetesK Kubernetes
            @Kubernetes nice, that's modifiable.. or are you going to leave them an PR (issue)?
            KubernetesK 1 Reply Last reply
              KubernetesK Offline
              KubernetesK Offline
              Kubernetes
              @robi I think it is a issue with the Cloudron implementation of OpenID to the audiobookshelf, because the error comes from Cloudron, but not from the iOS App
                @Kubernetes hopefully logs from both help someone figure out which needs modification.
                  KubernetesK Offline
                  KubernetesK Offline
                  Kubernetes
                  @robi In Audiobookshelf is in the admin panel a Config Page for Authentication. And there is a client redirect url thing, but even if I use a * for any url, it doesn't work...
                    bug.. -> issue
