  2. FreshRSS
  3. Problem moving FreshRSS instance (OIDC Authentication)
Scheduled Pinned Locked Moved FreshRSS
5 Posts 2 Posters 2.4k Views 2 Watching
  • P
    P
    p44
    wrote on last edited by p44
    Dear all,
    I'm moving a FreshRss instance from domain1.com to domain2.com (both are on two different Cloudron instances)
    Domain1.com has "admin" user configured, with traditional access (not OIDC).
    I created domain2.com FreshRss cloudron app, then imported domain1.com backup.
    Domain1.com has "admin" as unique and default user. Domain2.com comes with Cloudron main user.
    Basically, now I've all feed stored under "admin" user, so I cannot login on Domain2.com with "admin" user.
    I logged Domain2.com in with default Cloudron user, and configured classic login option (not OIDC), so I can login with "admin" user with all feed stored, but when restarting app, login option has been automatically restored to OIDC.
    alt text
    I'm not a bit confused... can you help me how to manage this problem?
      @p44 it might be easier to export the OPML of admin user in the old instance and import it into the new instance.
      (Otherwise, one has to dig into all the freshrss specifics of user management + OIDC).
      • P
        P
        p44
        @girish thank's, a the moment, I changed manually config.php:
          'auth_type' => 'form',
        This value seems to be not persistent, but is ok...
          @p44 auth_type will get overwritten depending on auth type chosen at install time.
            P
            P
            p44
            @girish Thank's Girish 🙂
