  2. Nextcloud
  3. Anyone have an issue with Nextcloud web interface login timeout?
7 Posts 4 Posters 1.3k Views 4 Watching
  • marcusquinnM Offline
    I used to stay logged in for days.
    Now I'm getting logged out multiple times a day when inactive.
    I don't think anything has changed with my desktop setup.
    iOS app is staying logged in indefinitely.
    Just looking for clues on if I'm the only one.
    • jdaviescoatesJ Offline
      Yes, see https://forum.cloudron.io/topic/11649/bug-auto-logout-with-and-without-inactivity-28-0-5/17
        @jdaviescoates Thanks. Seems to be a known issue, then, and a patch coming with 28.0.6.
        • marcusquinnM marcusquinn
          Dammit, just happened after a few minutes being logged in. Really is a nuisance!
            Seems solution might be using a Cloudron Collabora instance, instead of the local Nextcloud Office App. Will test...
            • necrevistonnezrN Online
              It happens with a separate OnlyOffice instance, as well.... So the local Nextcloud Office app might not be the culprit. Rather it seems it just happens across the board: https://github.com/nextcloud/server/issues/45132
              • murgeroM Offline
                murgeroM Offline
                murgero
                wrote on last edited by murgero
                Looks like there is an upstream fix: https://github.com/nextcloud/server/pull/45093
                Cloudron will need to update, but next NC version fixes it, it looks like. Cloudron's packaging may need to pull the update manually, but it looks like it's a quick fix.
                https://urgero.org
