  2. Pixelfed
  3. Settings not saved in admin panel
Scheduled Pinned Locked Moved Solved Pixelfed
4 Posts 2 Posters 2.2k Views 2 Watching
  • mgn841M
    mgn841M
    mgn841
    Hi there! I was using Pixelfed a year ago (or more) and I had a problem when I tried saving settings in the admin panel. I was not given an error, but the settings were not saved. So I gave up using it, thinking it would be fixed in the future. Now, I came back and see there has been a lot of development. But my problem still remains. No matter what setting I try to disable or enable, it just isn't saved. I looked around in the forum, and I don't see anyone else talking about this 🤔 I tried from a different browser, I tried from my phone. I also ran the commands. sudo -E -u www-data php artisan cache:clear sudo -E -u www-data php artisan optimize:clear sudo -E -u www-data php artisan optimize But it won't save. I am able to edit the .env file directly. But it would be nice to be able to use the admin page. So what exactly did I miss?
    • mgn841M
      mgn841M
      mgn841
      Just realized that this is probably related to the post below: https://forum.cloudron.io/topic/11247/delete-server-rules-button-does-not-delete-rule/41
        @mgn841 yes, it's the same bug. It's not clear what the issue is, I think the upstream author was investigating the issue.
          This is finally fixed in the new package.
