  3. Cloudron dash is stuck in reconnecting loop
troubleshootingdashboard
27 Posts 3 Posters 7.5k Views 3 Watching
    @mpeterson0418 You should not see the setup screen. It's almost like the database is entirely gone. I recommend contacting us at support@cloudron.io , so we can check what has happened.
    mpeterson0418M
    mpeterson0418M
    mpeterson0418
    @joseph
    Thanks I just sent an email to support@cloudron.io
    If that's the case.... is there something on the backend here for my account which would contain a backup I can recover from? I'm a bit confused on what's going on here
    Aside from a MySQL DB recovery, this is not what I expected to see. Is my website completely hosed at this point?
    • J
      @mpeterson0418 the app database is totally separate from cloudron's own database. But we have to see what is the state of the server to assess the situation.
      mpeterson0418M 2 Replies Last reply
        mpeterson0418M
        mpeterson0418M
        mpeterson0418
        @joseph
        Ok well that makes more sense.... I guess lol
        To be honest from a website perspective I didn't touch a thing on here. So whatever is going on at this point I'd be very curious to know. Honestly only other thing I could imagine here would be some potential disk corruption of some sort..... but hopefully you can give some better insight on that after looking things over
          mpeterson0418M
          mpeterson0418M
          mpeterson0418
          @joseph
          FYI the SSH access has been fixed. You should be able to remotely connect to the server for review
          • J
            @mpeterson0418 so the issue was that mysql, docker, containerd were all corrupt. I am not sure what happened to the disk or the server. I restore mysql from a previous backup. container/docker (i.e /var/lib/docker and /var/lib/containerd) had to be deleted entirely and re-created .
            mpeterson0418M 1 Reply Last reply
              mpeterson0418M
              mpeterson0418M
              mpeterson0418
              @joseph
              Thank you for all your assistance. Everything looks great now!
              Send you a couple other questions in the support case I raised. If you don't mind following up with me on it.... and then I believe we can close this one out
              • J
                @mpeterson0418 I found that the root file system was either corrupt or "reset" . I don't know and unable to guess what happened to the disk (maybe power outage?), but I can explain what I did to recover.
                • I found host MySQL to be empty. The box database had tables but was empty. The fact that it had tables meant that migration scripts were run on this . Maybe /home/yellowtent/box/setup/start.sh was run at some point on an empty (i.e no tables even) database.
                  • Usually, the last well known mysql dump is located /home/yellowtent/boxdata/box/box.mysqldump . One can also find the same inside the latest backup (inside the box.tar.gz) .
                  • To "restore", mysql -uroot -ppassword < /home/yellowtent/boxdata/box/box.mysqldump
                • Then I found, docker won't start. In Cloudron, containers are throw away infrastructure since data is stored outside the containers. I tried cloudron-support --recreate-docker but this did not work. On investigating further, it seems /var/lib/containerd was also corrupt . Corrupt here means no docker commands work. So, I removed that directory as well. After that, cloudron-support --recreate-docker worked.
                The best way to migrate in Cloudron is not to do the above but instead just restore from backups. See https://docs.cloudron.io/backups/#move-cloudron-to-another-server .
