  3. Severe DNS problems (still on 7.7.2)
upgrade
10 Posts 2 Posters 4.1k Views 3 Watching
  • C
    C
    cstork
    I don't know how it got so far but it seems my DNS lookup fails already for quite some time. I had problems before but then it seemed that restarting unbound after it went down solved the problems.
    $ nslookup example.com
    ;; Got SERVFAIL reply from 127.0.0.53
    Server:		127.0.0.53
    Address:	127.0.0.53#53
    ** server can't find example.com: SERVFAIL
    I'm running Cloudron 7.7.2 on Ubuntu 20.04.2.
    $ sudo cloudron-support --troubleshoot
    [sudo] password for cstork:
    [OK]	node version is correct
    [OK]	docker is running
    [OK]	MySQL is running
    [OK]	nginx is running
    [OK]	box is running
    	unbound is down. updating root anchor to see if it fixes it
    [OK]	unbound is running
    [OK]	Dashboard is reachable via domain name
    getaddrinfo(whois.denic.de): Temporary failure in name resolution
    [WARN]	Domain eichenlaub.de expiry check skipped because whois does not have this information
    What's the best way to further analyse this?
    • J
      @cstork I think this happened because of a failed upgrade to Cloudron 8. Please do this:
      • apt remove resolvconf
      • systemctl start systemd-resolved
      • In /etc/resolv.conf, you should have see nameserver 127.0.0.53 (which is systemd-resolved)
      • At this point, nslookup should work. If it does not , it means that systemd-resolved does not have nameservers. Check the output of resolvectl to see what nameservers it has. You can edit /etc/systemd/resolved.conf and put the DNS=1.1.1.1 for example and systemctl restart systemd-resolved.
      • Once the DNS works, upgrade to Cloudron 8 immediately .
      • C
        C
        cstork
        I don't think there was an attempt to upgrade to 8 yet. I think the DNS problems were there already before.
        Anyway, here's what I got:
        root@my:~#  apt remove resolvconf
        Reading package lists... Done
        Building dependency tree
        Reading state information... Done
        Package 'resolvconf' is not installed, so not removed
        0 upgraded, 0 newly installed, 0 to remove and 117 not upgraded.
        root@my:~#  ps aux | grep resolv
        systemd+     762  0.0  0.1  24000  5604 ?        Ss   Sep25   0:08 /lib/systemd/systemd-resolved
        root@my:~#  cat /etc/resolv.conf
        options edns0 trust-ad
        root@my:~#  resolvectl status
        Global
               LLMNR setting: no
        MulticastDNS setting: no
          DNSOverTLS setting: no
              DNSSEC setting: no
            DNSSEC supported: no
                  DNSSEC NTA: 10.in-addr.arpa
                              16.172.in-addr.arpa
                              168.192.in-addr.arpa
                              17.172.in-addr.arpa
                              18.172.in-addr.arpa
                              19.172.in-addr.arpa
                              20.172.in-addr.arpa
                              21.172.in-addr.arpa
                              22.172.in-addr.arpa
                              23.172.in-addr.arpa
                              24.172.in-addr.arpa
                              25.172.in-addr.arpa
                              26.172.in-addr.arpa
                              27.172.in-addr.arpa
                              28.172.in-addr.arpa
                              29.172.in-addr.arpa
                              30.172.in-addr.arpa
                              31.172.in-addr.arpa
                              corp
                              d.f.ip6.arpa
                              home
                              internal
                              intranet
                              lan
                              local
                              private
                              test
        Link 46 (veth7845bc1)
              Current Scopes: none
        DefaultRoute setting: no
               LLMNR setting: yes
              DNSSEC setting: no
        ... lots more veth....
        Link 4 (br-9ecb37f36dc9)
               LLMNR setting: yes
              DNSSEC setting: no
        Link 3 (docker0)
               LLMNR setting: yes
              DNSSEC setting: no
        Link 2 (ens32)
               LLMNR setting: yes
              DNSSEC setting: no
        root@my:~# echo DNS=1.1.1.1 >> /etc/resolv.conf
        root@my:~# systemctl restart systemd-resolved
        root@my:~# ping google.com
        ping: google.com: Temporary failure in name resolution
        J 1 Reply Last reply
        • C
          C
          cstork
          Oops, wait! By now the DNS entry in /etc/resolv.conf has disappeared again. Give me some more time to figure out what to do....
          • C
            C
            cstork
            Ok, so this fixed it... for now:
            sudo resolvectl dns ens32 1.1.1.1 8.8.8.8 && sudo systemctl restart systemd-resolved
            But I'm still baffled as to how it could get into this state. Any idea?
            • C
              C
              cstork
              However, this does not survive a reboot:
              # after reboot
              $ resolvectl dns ens32
              Link 2 (ens32):
              How do I permanently change the nameserver (and why was it "unset" without me doing anything)?
              • C cstork
                Global
                       LLMNR setting: no
                      DNSSEC setting: no
                                      16.172.in-addr.arpa
                                      17.172.in-addr.arpa
                                      18.172.in-addr.arpa
                                      19.172.in-addr.arpa
                                      20.172.in-addr.arpa
                                      21.172.in-addr.arpa
                                      22.172.in-addr.arpa
                                      23.172.in-addr.arpa
                                      24.172.in-addr.arpa
                                      25.172.in-addr.arpa
                                      26.172.in-addr.arpa
                                      27.172.in-addr.arpa
                                      28.172.in-addr.arpa
                                      29.172.in-addr.arpa
                                      30.172.in-addr.arpa
                                      31.172.in-addr.arpa
                                      corp
                                      d.f.ip6.arpa
                                      home
                                      internal
                                      intranet
                                      lan
                                      local
                                      private
                                      test
                       LLMNR setting: yes
                      DNSSEC setting: no
                       LLMNR setting: yes
                      DNSSEC setting: no
                Link 3 (docker0)
                       LLMNR setting: yes
                      DNSSEC setting: no
                Link 2 (ens32)
                       LLMNR setting: yes
                      DNSSEC setting: no
                @cstork said in Severe DNS problems (still on 7.7.2):
                Oh no, this is not correct...
                • /etc/resolv.conf should look like https://paste.cloudron.io/jikayupofe.apache
                • Then in /etc/systemd/resolved.conf (which is not the same as above file!) , edit DNS=1.1.1.1 . Usually, there is already a commented out line in this file. After making that changed systemctl restart systemd-resolved
                • C
                  C
                  cstork
                  Hmm, my /etc/resolv.conf lacks the last line:
                  # This file is managed by man:systemd-resolved(8). Do not edit.
                  # This is a dynamic resolv.conf file for connecting local clients to the
                  # internal DNS stub resolver of systemd-resolved. This file lists all
                  # configured search domains.
                  # Run "resolvectl status" to see details about the uplink DNS servers
                  # currently in use.
                  # Third party programs must not access this file directly, but only through the
                  # symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way,
                  # replace this symlink by a static file or a different symlink.
                  # See man:systemd-resolved.service(8) for details about the supported modes of
                  # operation for /etc/resolv.conf.
                  Do I need to fix that?
                  Re /etc/systemd/resolved.conf: indeed I confused the two files and now – with the edit – DNS lookup works even after reboot! Thank you!
                  However, I still had problems with the Cloudron OpenID login to my apps. I ran:
                  [OK]	box is running
                  [WARN]	Domain xx expiry check skipped because whois does not have this information
                  and that fixed the login issues apparently.
                  Now my only question is for a word of advice: First update to Cloudron 8 or to Ubuntu 22.04/24.04 ?
                  • C cstork
                    # currently in use.
                    [OK]	box is running
                    The search is not needed. It's used when you try to use names without fully qualifying them. For example, ping blah can magically become blah.mydomain.com or something else depending on how you configure search. This is not used by Cloudron in any case...
                    Update to Cloudron 8 and then you can upgrade ubuntu after. You cannot upgrade to Ubuntu 24 until upgrading to Cloudron 8...
                    • C
                      C
                      cstork
                      Great! Thank you!
                      BTW, it seems in retrospect that the start of the DNS problems coincided with me beginning to use the OpenVPN app. Take that for whatever it's worth.
