  3. Concern/Question: You have xxx active web token(s)
sessiontokens
5 Posts 2 Posters 1.9k Views 2 Watching
  • SansGuidonS Offline
    SansGuidonS Offline
    SansGuidon
    Hi
    I logged into my Cloudron instance this morning and in my profile and I have noticed that message You have 1134 active web token(s) and 0 CLI token(s).
    I had no idea I had so many web tokens and I have no clue what to do with this information. Can I dig deeper and learn more about this ? I don't want to "logout from all" without understanding anything.
    Thanks in advance 🙂
    About me / Now
      That does sound like too many. Maybe there are old leftovers from previous buggy Cloudron versions, but for a start, do you happen to have any scripts running somewhere which perform a login to use the Cloudron API or so?
      A "logout from all" should be fine, unless there are actual bugs or you have somehow extracted access token from the webui for further use, everything should make you properly re-login if those are even used still.
        SansGuidonS Offline
        SansGuidon
        Thanks! I've applied the advice immediately.
        I notice the impact is partial and sometimes a few dozen or hundred tokens are gone, but lot are left. So it worked in the end but I had to hit the button a few times (7-8?) until reaching 0 and being finally logged out while I would have expected clicking once for all would be enough 😅
        About me / Now
          That is strange, just looked at the code and at least there is no pagination issue, but tokens are revoked individually so in your case that would have been 1134 individual API calls, maybe it just took very long...
            SansGuidonS Offline
            SansGuidon
            You know better, so anyway the problem is resolved in the end and that didn't take long, so many thanks! 🙂
            have a great week-end ahead
            About me / Now
